SOURCE: WHIRLPOOL DUET GHW9100 FRONT LOAD
Take the top off the unit,and check the springs..there are 4 on top and 4 on the bottom..make sure they a attached..and tighten
SOURCE: Whirlpool Duet GHW9150P knocks when spinning
I had that problem while the washer was under warranty. Luckily my neighbor is a repair man. He removed the front cover just under the door. There are shocks under the barrel that keep it aligned. One of mine was damaged and the barrel became misaligned. Check that area, that might be your problem. Good Luck!
SOURCE: Whirlpool Duet WFW9200SQ has knocking sound
the problem is a cracked spindle on the back of the drum. It most likely also tore up the grey plastic front shield.The only thing to do is throw the machine out sine the drum cost parts onle is over $400 for drum, and over $400 for the front plastic.l
SOURCE: My Whirlpool Duet washer makes
it sounds like you need a new inner tub,the three cross member sound like there broken
SOURCE: whirlpool duet sport making a clicking/knocking
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
