Question about Garden
Need image of throttle linkage assembly on a sachs dolmar 100 chainsawplease..? Thank you much.
Anonymous
SOURCE:
dontbother10
dontbother10
  • 2220 Answers
SOURCE: I need a coil for a Sachs Dolmar
This is a an old saw. I suggest you try here:
ArboristSite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9
I did a search for "Sachs Dolmar Super 133" and got over 10 hits.
Please search the existing posts before asking your question, the answer may have been asked and answered. It is free to join if required. They are a collection of chainsaw enthusiasts and very helpful.
This guy is a Dolmar dealer and dealt with them for many years.
http://www.arboristsite.com/member.php?u=3404
Scott has an operational radial dolmar... pretty cool. GL
Lou
I think this answers your question fully. Please rate my answer.
Posted on Sep 14, 2009
dontbother10
dontbother10
  • 2220 Answers
SOURCE: sachs dolmar over oiling chain
I am not familiar with your specific saw. That said on most saws, under the clutch cover, below the clutch is an adjustment for the oil pump.
This is a Husky:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_1150183-95.pdf top right page 34 example,
On my Pioneer it is under a cap screw. HTH
Lou
You might also try here:
ArboristSite.com Chainsaw thread (free to join)
This is a collection of professionals, amateurs, mechanics, and whole bunch of nuts. At least member has a rotary engine Sachs Dolmar.
Posted on Oct 01, 2009
Joe Hogan
  • 10865 Answers
SOURCE: I have a 114 sachs dolmar chain saw what is the
2.6 ounces of oil per gallon of gas. Joe. here is a manual in case you don't have one. http://www.dolmarpowerproducts.com/downloads/373/DOLMAR_Catalog.pdf
Posted on Jun 07, 2010
skookumfab
Bob Foster
  • 93 Answers
SOURCE: Fuel mix and slow/fast running jet ajustment
Set both the high and low speed screws from lightly seated to 1 1/4 turns out. This will give you a rough setting that will allow the saw to start and idle. Set the idle screw to where the chain just stops moving at idle.
With the saw warmed up adjust the low speed screw out until the saw smokes a bit and acceleration is sluggish. Bring the screw in small steps until the hesitation is gone from the acceleration...you may need to adjust the idle again after this.
Now hold the throttle wide open and while it is wide open adjust the high speed screw in until the noise becomes smooth and the saw "sings". Do not leave it at this setting as it will burn down in short order. Once the saw is singing back the screw out until you can hear the saw's tone "roughen"....then back the screw out a tad more for good power / fuel under load.
That's it in a nutshell...here's a good link also...
http://www.youtube.com/watch?v=3Lw0pJcEPYo&feature=player_embedded
Posted on Dec 08, 2010
Eugene Rounds
  • 1169 Answers
SOURCE: what is the 2cycle mix for the sachs dolmar chainsaw 120si it is pre mix by hand
40:1 mix ratio.
Posted on Mar 23, 2015
I require the complete starting assembly for a Sach DolmAR CHAINSAW, mODEL 116SI
go e-bay and search for-- recoil starters for small engines
or
recoil starter for dolmar chainsaw
Nov 26, 2016 | Garden
Coil for sachs dolmar model 120 chain saw
Ignition Module Coil for Dolmar Maybe for your Country otherwise search by Makita also there are several equvalent parts to get forSachs Dolmar and its cheaper , beware on this to order ignition coils by mention on the serial motor number and the year of build by all orderings if it must be the right combination to get it can be important by marketing technical upgrades / modifications because of changed flywheels in several Dolmar models over past time i know. a suggested coil in a link
Oct 29, 2016 | Garden
Sachs Dolmar Manual
first see if the shaft is available, then with light oil oil up all the parts that are going to be disassembled, let sit overnight, then take apart, you might need to heat some of the parts to get them free, if all goes well order the parts. and your back on the road.
Nov 13, 2013 | Garden
The rubber mounting syst. is broken on my 114 sachs
Sachs Dolmar support is very difficult to find. Some of these gals and guys were dealers when these were first introduced. Please do an inquiry first and post your need where most applicable. There are many Dolmar threads.
HTH
Lou
One of these guys has a rotary engine Sachs... pretty cool.
Oct 02, 2009 | Makita Garden
Sachs dolmar over oiling chain
This is a Husky:
Lou
Sep 30, 2009 | Garden
Lou
Sep 14, 2009 | Garden
Garden Logo
37 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
