Setting alarm on model 66000 - Audio Players & Recorders
  • 67 Answers
What brand is this?
Posted on Jan 25, 2020
How do I switch off the alarm on my CR1003 (model Number) Blaupunct bedside radio?
Setting the Alarm
1. Press and hold the 'Alarm/Sleep/Snooze' button to enter alarm mode.
2. 'Alarm Status' will be displayed and 'ON' or 'OFF' will flash on the second line of the display. Use the right hand rotary control to change the display to 'ON' or 'OFF' as required and press the right hand rotary control to confirm.
Stop the Alarm
When the alarm sounds press the 'Standby' button on the top of the radio. Alternatively, you can press 'Alarm/Sleep/Snooze' on the top of the radio.
Turn off the Alarm
Follow steps 1 and 2 in 'Setting the Alarm' and select 'OFF' in step 2.
Snooze function
When the alarm sounds, you can press the 'Alarm/Sleep/Snooze' button on the top of the radio. 'z' will be displayed in the bottom right of the display and the alarm will sound again in approximately 5 minutes.
Apr 16, 2017 | The Audio Players & Recorders
Why does my nokia 3600 alarm not work?
I have not used this model phone before, however, there are a few universal things you can check for alarms in general:
Have you verified that the tone used for the alarm is something you can hear?
Have you tested by setting the alarm to sound say 2 minutes from now?
Is there no system sound setting that is turned down too much?
Is your phone region/timezone set correctly? Some users of this phone have reported that the alarm rings at the wrong time & it was determined to be due to the timezone.
Feb 03, 2015 | Nokia Cell Phones
I need help setting the alarm on my vintage Sanyo Model RM 5005 radio
I just brought the same one at a garage sale, after a bit of fiddling around, i figured it out
To set the time:
1. Hold down the 'real' button
2. While holding it down, push down hour until you have the desired hour (if you want pm, you need to go around until the 'pm light' is on
3. While still holding down the real button, push the minute button until desired number is reached
To set the alarm:
1. Hold down the alarm button
2. Follow steps 2 and 3 of setting the time, except with the alarm button held down instead of the real button
Jan 30, 2015 | Sanyo Audio Players & Recorders
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Set date on 1440 sports watch 504-t5k085
    My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
    Upper left button: press to switch to a stopwatch, or...
    Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
    -- you can only do one or the other without exiting the setting
    mode (time or alarm set).
    - within the setting mode you use the two right side buttons
    in obvious ways to set times/dates
    Exit setting mode by pressing upper left again
    Lower left button: light
    Upper right button (when not setting time): reveal date while pressed
    Lower right button (when not setting time): reveal alarm time while pressed.
    ALSO: WHILE lower right button is pressed you can change alarm
    on/off and chime on/off through the four possible settings by
    secondarily pressing the upper right button repeatedly.
    Mar 01, 2012 | Timex 1440 Nylon watch
    I have the smart alarm clock model number 4511. I can't remember how to change the time for the alarm. I have pressed everything.
    Open the door on the bottom of the clock. There's a switch there that unlocks the time setting function. After you unlock it, you can use the < and > buttons on the top of the clock to move the time back or ahead. Use the "mode" button to select between time and alarm setting functions.
    Jul 11, 2011 | Brookstone SmartSet Alarm Clock
    Need instruction for setting clock model # 38229-1 Atomic Clock - Sio/Scan (Equity Time). Need to set time, time zone and date. blainep
    Setting timezone: Enter alarm time preview, by pressing "Mode". Press "Adjust" to change time zone.
    Setting time: When previewing time, press and hold "Alarm on/off" Until time blinks. Press "Adjust" to change time; Press "Alarm on/off" to change to minutes, ect. Press "Mode" when done.
    Nov 29, 2009 | Audio Players & Recorders
    I just moved into a home with a kenmore chest freezer. This is a real dumb question, but which symbol means on. Should the circle be showing for "on" or should the line be showing for "on"?
    Some freezer models feature a temperature
    monitor that provides an audible
    alarm. The temperature monitor alarm is
    located near the temperature control
    The alarm sounds if the temperature in
    the freezer rises 10° F (12° C) or more
    above normal for selected setting. Alarm
    may sound if temperature control dial is
    turned to a much colder setting or if a
    large amount of unfrozen food is added at
    one time. Alarm is controlled by a three
    position switch
    0 = OFF prevents alarm from sounding
    when freezer is warm, such as during
    initial start-up or defrosting.
    • ✓ = TEST sounds alarm regardless of
    temperature. Alarm system should be
    tested at least once a month.
    1 = ON is proper setting for normal
    freezer use. Return switch to 1 after
    defrosting.
    Jul 07, 2009 | Kenmore Freezers
    Changing code on home alarm system
    important. What model is your alarm system
    May 10, 2009 | Home Security
    26 people viewed this question
    Ekse
     Grubhead
    Grubhead
