Question about The Audio Players & Recorders
Hizpo my radio will not change stations well it changes stations but no frequency response everything else works fine on the radio Bluetooth mapping everything but when I turn the dial it does change stations but only goes to the ones that are memorized those stations do not play no music
Anonymous
SOURCE:
Anonymous
SOURCE: How do I reset the radio alarm preset on Timex (T307S) Clock Radio
if the radio alarm is still showing the nonexistent 98.5, you would need to reset the radio alarm. Press and hold button 1 (top left hand side) until the display starts blinking. Then press the preset button for 98.1. It should then display 98.1 on your radio alarm. good luck this is the most difficult set of instructions I've seen yet
Posted on Oct 02, 2007
Anonymous
SOURCE: Will not do anything
PLEASE HELP USE
Posted on Jan 14, 2008
Anonymous
  • 108 Answers
SOURCE: need to change hold music ASAP
How about turning off the Music On Hold source at the phone system. It will be an external device ( radio, mp3 or cd player ) and turn it back on when you are on-line.
Posted on Jul 28, 2008
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
SOURCE: sansa clip 2mg fm radio not putting out sound
Go into the Settings menu of the Sansa, and change the region to "World" if you live outside the US, and change to "United States" if you live inside the US. Then, go back to the Radio mode and see if there is an icon that looks like a block (technically, a "Stop" sign) - if there is, press up on the clickwheel - it will get your radio off of pause mode. You radio should now work again.
Posted on Mar 31, 2009
Anonymous
SOURCE: Radio won't work on my Dual XD1222
same problem, but if i disconnect unit or car battery systems (resets?) works again for a day or two then problem comes back
Posted on Feb 07, 2010
I am trying to re tune to my local radio station radio Merseyside on dab but it says station not available or goes to another station ?
Have you checked the frequency of that Station?
Also check your aerial.
I have also found this:
Listeners to DAB digital radio in the Merseyside area will need to retune on Wednesday 20th April following a frequency change that will affect local radio stations.
The local DAB multiplex carrying BBC Merseyside, Radio City 1-3 and Capital Liverpool among others will be moving to a new frequency in order to allow better reception over a wider area. The current frequency will be turned off late on Tuesday 19th April. The new frequency will go live from 6am on Wednesday 20th April, after which listeners will need to rescan their DAB radios in order to continue listening.
May 26, 2016 | Audio Players & Recorders
Radio Station Keeps Changing Automatically
hi there is a option in the settings to automatically search for the station if frequency changes try turning it off to see if that helps
Mar 23, 2014 | 2006 Hyundai Accent
Lost all radio stations on my Sherwood RX4030R
It certainly sounds like the main tuner has failed, if IC301 does that function I would replace it and see what happens.
May 25, 2017 | Sherwood Audio Players & Recorders
After an oil change the touchscreen on the navigation/radio/bluetooth is not responsive? How do you fix this issue?
I have no clue what changing the oil would have to do with any of this. However, the problem you are describing sounds a lot like the types of problems that occur with a shorted battery cell. I would take a HARD look at the battery and charging system. If your battery is more than 4 years old, it is time to replace it.
If the battery and/or charging system is the cause, you will also very likely have fault codes stored in several of your computer modules. You will have to clear all of these codes from all modules and force a "clean boot" of your computer network to get everything working properly.
Dec 23, 2011 | 2005 Cadillac STS
How do i change the AM radio to FM?
Hello
Press RADIO BAND.AUTO PRESET until the band you want appears in the display (direct power on). Each time you press this button, the indication changes as "FM" --> "AM". Hold down TUNE + or --, until the frequency digit begins to change in the display. The player automatically scans the radio frequencies and stops when it finds a clear station. If you can't tuned in a station, press the button repeatedly to change the frequency step by step. If FM broadcast is noisy, press "MODE" until "Mono" appears on the display and the radio will play in monatural without any noise. Only strong FM signals can be decoded to stereo. OK.
Oct 22, 2011 | Sony CFD-S300 Radio/Cassette/CD Boombox
How do you auto preset radio stations?
Hello
[1] Press RADIO BAND.AUTO PRESET until the band you want appears on the display [direct power ON]. Each time you press the button the indication changes as follows. "FM" => "AM"
[2] Hold down TUNE+ or --ve until the frequency digits begin to change in the display.
The player automatically scans the radio frequencies and stops when it finda a clear station. If you can't tune in a station, press the button repeatedly to change the frequency step by step.
If FM band is noisy, press the MODE repeteadly until "MONO" appears in the display and the radio will play it monatural. If FM radio signal at your area is very weak, this type of noise may occur. OK.
Sep 28, 2011 | Sony CFD-S350 Radio/Cassette/CD Boombox
FM Transmitter does not connect to car radio, have FX signal and Line out works.
Car cradle works "wirelessly" with Car Radio (inherent design of unit). Place Unit in Cradle; connect Cradle to Auto Power Source, and SkyFi3 should power on. Press Menu to Get FM Radio station channels; select a lower station Channel Frequency i.e. 88.3 or any vacant channel number and the signal should transfer to your Radio speakers automatically. You can change Station frequencies as often as you need to do so--for example if traveling through different broadcast areas, some channels frequencies are clearer than others. Good luck.
Jul 19, 2010 | Delphi SKYFi3 XM Radio Receiver
Pioneer deh4000ub radio wont save
Six stations for each band can be stored. 1 Press LIST.
Preset screen is displayed.
2 Use MULTI-CONTROL to store the selected
frequency in memory. Turn to change the preset number. Press and hold to store. You can also store the frequency in memory
by pushing and holding MULTI-CONTROL right.
3 Use MULTI-CONTROL to select the desired
station. Turn to change the station. Press to select.
You can also change the station by pushing MULTI-CONTROL up or down.
To return to the ordinary display, press BAND/ESC or LIST.
Jul 18, 2009 | Pioneer DEH-400UB Car CD/ MP3 Player
Turner mode
To the right of the number 6 station preset is an auto/name button. In the display it likely shows something like auto 1 or 2. each press will cycle it through Auto 1 > Auto 2 > Manual. You want the manual setting. See if that works for you.
Mar 22, 2008 | Kenwood KDC-X717 CD Player
29 people viewed this question
Top The Audio Players & Recorders Experts
Roy Cunningham
Level 1 Expert
Michael Roth
Level 1 Expert
Martin van der...
Martin van der...
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
