The service manual is posted in this but if you dont have the test gear that is required, it is not much use. https://www.scribd.com/document/143852098/PB12-JBL-pdf
SOURCE: pb12 makes thumping sound after warming up
Hello there..Thats normal only if your sub volume and the pre amp is turned up..Your amp is the cause of the speaker jump..Turn amp volume sub level down a few and check your wire from sub to amp..If all of that is good is a normal operation for pre amp warm up in sub if level is turn to max..Try unplugging amp freom sub then turn sub on stand alone(just sub outlet plugged in and no wires from base amp plugged in..If sub stops the its the amp making the problem..If it still is there then the pre amp is either dusty on inside or the outlet plug that it is plugged in doesnt have a good ground..Hope these help to solve your problem..Have a great day...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
SOURCE: JBL PB12 will have loud thump or pop!
First try to find the source of your problem. The easiest way would be to try your sub with a different audio source to see if the problem still occurs but is sounds more like there's a problem with the receiver.
