Question about Panasonic Televison & Video
I have a Panasonic large screen TV that won't turn on. I want to buy a replacement part but not sure which to buy.
    Top Expert:
  • Panasonic Master
  • 30,873 Answers
If it is a Projection television, throw it away, it is antique. Once they start to go, you will be chasing failed parts.
Posted on Jan 20, 2020
Anonymous
SOURCE:
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
Panasonic tc-p60gt30 won't turn on. Something hit screen. Screen did not crack but now won't turn on
May have damaged the PDP (plasma display panel) inside---if the panel which is fragile shorted inside it will trigger shutdown.
Aug 28, 2012 | Panasonic 60 TCP60GT30 3D Plasma TV
Panasonic tv model tc-p42c2 remote is inop
It is a common thing that all the buttons of a universal remote control might not work, as it meant to be. Try an other code. If this too won't help you, there is no other way than buy a new original remote control for your Panasonic TV. You can buy in from the authorized service center for Panasonic at your town. Just give them the exact model number to your TV. They will provide you the original one.
Jul 20, 2012 | Panasonic TCP42C2 42 in TV
CRT fluid for Philips 60PL92000D
  • dEAR sIR:
    Turn on the TV set, bring up the convergence menu and make sure the three colors--red, green and blue--converge and overlap at the cross in the center of the screen. This is needed to help converge the TV later. Turn off and unplug the TV.
  • 2
    Remove the front screen by popping off the bezel and pulling the three combined screens out. Place wide cellophane tape around the frame to prevent the three screens from separating. Lay the screen someplace where it won't be bent or scratched.
  • 3
    Remove the circuit board from the bottom of the CRT neck. It may be held in place by one screw or glued in place with silicon. Pull it out without twisting it.
  • 4
    Disconnect the large red wire from the high voltage transformer by grasping it with a large side cutter and rocking it from side to side to lift up the fastener. Disconnect the two bundles of wires from the main circuit board and leave them hanging from the CRT.
  • 5
    Remove the ground connectors by releasing their tabs with a narrow screwdriver.
  • 6
    Remove the CRT assembly from the TV by removing its four flat-bladed screws and pulling it out of the TV. Lay the CRT down with its filler plug facing up in a location far away from the TV's circuit boards.
    sincerely. God bless you
    ernesto cuaddra
    managua, nicaragua
  • Feb 15, 2012 | Philips 60PP9202 60" Rear Projection...
    !0 blinks on my panasonic plasma tv
    Hello!
    Sorry for your issue! Blinking 10 times means: main board must be replaced!
    Panasonic is very proprietary manufacture! You must obtain prior "authorization" to buy that board. Prepare to spend around $500 to get the board. then you muse send back 'dud" or "core' undamaged, for about $200 credit. won't recommend to buy any used boards or from e-bay. Even if those might work, soon they will quit same way. Welcome to "global economics"! they think: Americans are walking "sacks full of money" and want US to keep buying "disposals", whether TVs or cars or "whatever"! nobody offers "disposable" housing or 'money".
    good luck with your project. Make sure, have those## off the board written correctly: TV's model# might mismatch the actual board. Look for 'prefixes".
    thanks,
    Alex.
    Nov 15, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
    Panasonic viera Plasma TV model TH-P42X10A The tv
    The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
    I hope this will help in solving the problem....
    Aug 01, 2011 | Panasonic Televison & Video
    I have a panasonic projection TV, PT-60C13 that will not turn on. Upon pressing the power on button, the button flashes green many times, then flashes red five time then one orange flash. This red/orange...
    The most common cause of Panasonic Rear Projection LCD TVs not starting is bulb failure. The PT-60LC13 users manual gives some help in translating the LEDs on the front of the TV.
    If the TV worked normally for a period of time (months or years) and won't start, the most likely cause is bulb failure. There is no way to measure the bulb, sometimes the bulb is visibly damaged when it fails. Remove the Lamp Assembly and look at the bulb.
    If there was an On-Screen Lamp Replace warning and TV won't start, bulb has failed.
    The first step with all Panasonic Rear Projection TV "No Picture" problems is bulb replacement. If that does not remedy the problem, get a technician, there are no user serviceable parts. Guessing if the ballast, power supply, controller board or optical engine is faulty is not practical.
    The Panasonic Lamp Gallery shows all Panasonic models and Lamp Numbers. There is also a link to Panasonic DIY bulb and lamp replacement.
    easyab
    May 05, 2011 | Panasonic PT-60LC13 60" Rear Projection...
    I have a large screen panasonic tv. The lamp
    Turn On tv.
    Press and hold Volume Down button on TV Front and PIP/ SPLIT button on Remote at same time for 6 Seconds to reset Lamp Timer and tv will show you timer reset message screen.
    Hope this info will help you.
    Thanks.
    Mar 31, 2010 | Panasonic PT-50LC13 50" Rear Projection...
    Panasonic PT-47WX42F outer most screen cracked
    Look for a used Panasonic PT-47WX42F One in Local ads, Or place a wanted ad for your model. ~ Or if you want A new one, Get ahold of a TV Shop And OR Panasonic and be ready to spend lots of $$$$ ~ And yes there easy to replace!, Make sure you have a large clean area to work in, And a helper. Becarful and replace them back in as they came out! ( Top Bottom) they should be marked with a small tag or mark.... Geo*
    Jul 06, 2009 | Panasonic PT-47WX53 47" Rear Projection...
    Televison & Video Logo
    43 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
