SOURCE: 65 INCH PROJECTION SCREEN IS SUPER BRIGHT
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC). 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB
SOURCE: I have a philips 60 inch tv with on picture and sound
There are two common problems with Projection TV sets.
Problem #1) Convergence
Symptoms:
Problem #2 CRT Fluid has clouded over.
Symtoms
You can see some examples and find a fix here...
SOLUTION
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
The power supply will need to be replaced.
SOURCE: KP-65WS500 65 in. Rear Projection Television: 65 inch sony projection TV, just had the convergen...
call tech support with # of blinks
SOURCE: We went to turn our TV on and when it turns on the
The standby power supply resistors on the inverter board have changed values. You will replace resistors R1217, (820K 1/4 watt), R1218,(820K 1/4 watt) and R1219 (390K 1/4 watt). Please use the values just mentioned. Or you may have the inverter board replaced. Take this note to a TV repair Tech.Thanks for asking and show a few hands of support!
