J'ignore quelle est la marque de la tablette de votre enfant mais il se pourrait que ce soit un souci caus? par un d?faut de fabrication . Vous pouvez toujours remplacer certaines pi?ces,alors je vous recommande de cliquer sur ce lien
https://www.distriphone.com/en/53-iPad-Parts
SOURCE: I recently purchased an Archos
At this point you'll want to return or RMA the unit to Archos for repair/replacement. You can find information on how to do this on their homepage.
SOURCE: My samsung Tablet is 10 wks old, a month after I
You should return the device. It sounds like a problem with the hardware or the software. A good many rooted versions of android exp. these same problems also.
Testimonial: "wow that was quick thanks."
SOURCE: How do I reset a locked 7" lp tablet. My daughter
What type of tablet is it? Make and model name please.
I had similar problem and I opened the back and disconnected the battery for 30 seconds, then reconnected it. Everything worked properly when I turned the tablet on.
It sounds like you've done most of the things you would reasonably be expected to do to make it function; since it is only 2 months old I would strongly urge you to go back to the retailer and make them replace it or refund you, as your rights in most countries/states allow.
If you're set against doing this, try holding down the power and volume down key for at least ten seconds to see if this boots it into hard reset mode. If this doesn't do anything, try again holding down power with each of the other buttons to see if you can activate any other developer/reset modes.
However, I have read reports that this particular tablet has up to a 40% failure rate in its first six months.
If you can possibly get it refunded, do that and buy something else.
