Computers & Internet Logo
Laura Christiansen Posted on Jan 20, 2020
How do I register my flash drive - Computers & Internet
Artur Myakon'kiy
Level 1:
Habit-Forming:
  • Contributor 20 Answers
  • Posted on Feb 11, 2020
Artur Myakon'kiy
Contributor
Level 1:
Habit-Forming:
Answers
20
Questions
0
Helped
2372
Points
90
As you know that security matters (https://www.seedboxco.net/) have become an integral part of every organization and it is necessary to ensure that they are adequately secured.
Jane Smith
Level 1:
  • Contributor 4 Answers
  • Posted on Jan 22, 2020
Jane Smith
Contributor
Level 1:
Answers
Questions
0
Helped
116402
Points
13
You can get register for the flash drive through the internet. I use the <a rel='nofollow' href="https://du-home-internet.org/du-home-internet-services-surfing-really-fast-internet-on-vpn/">du home internet</a href> for faster internet connection.
I cannot get my cruzer glide flash drive to open up and let me access it on my Windows 7 which is an emachines
As the pen drive works fine on your laptop there is no problem with you pen drive the problem is with PC, Formating the PC might solve the problem
1helpful
I have a 16 gb that does not work right, it registers and then it doesnt register and repeats over and over again. how do i fix this problem?
You have to reformat the flash drive. Right click on the drive properties and click reformat. It will erase everything on it. But fixes most problems with flash drives.
1helpful
How to activate my usb flash drive do i need to register first to use it?????
You do NOT have to "Activate" your drive. It should work by simply plugging into any USB port, it should be automatically detected and installed, as a "Drive" and then it can be used as such, Cut, Copy, Paste. etc.
SanDisk 8GB lights up but wont register
This one is just a hunch. The drive might be bad but this is worth a try. Its possible the drive letter somehow changed on the flashdrive. Plug in the drive, RIGHT click on "My Computer" and select "Manage" from the drop down menu. Now select "Disk Management" from the list. If you see your flash drive on the list, right click on it and select "Change drive letter and paths", then click on "change", now assign it a new letter like "F" for example. Click ok, ok, ok. If it showed up the the list and it's still not registering, unplug it and plug it back in. Hope that helps.
2002 SATURN VUE AWD
the speedo/odometer are computer controlled by the BCM (body control module) and you may need to have The PCM re-flashed !
Please Help
Most likely, i think you might have a bad flash drive, or the drivers has been corrupted. Try cleaning your system drivers and use a program like DriverMax. It is free, just register and download the program, then, clear all your drivers and put in the flash drive again.
See if it works.
Flash drive repair
Some times if a flash drive is not ejected, if it is just pulled out, it can wipe all information. I learnt the hard way, make sure you eject each time.  Sorry if this is already known, some times it can be hidden if the file attributes  have been set to hidden. Try looking in you view option and see if they are set to hide files set to hidden.
hope it might help  Mr Fixitcv12
Flash drive does not connect and show up in my computer
are u use the win98
u must install the driver flash drive..
u can find it the driver at fixya browse manufacturer..
before u find it,u must register member as www.fixya.com
its free..
if u use the winxp
the flash drive will automaticlly detect on your computer,,
happy trying
good luck
tq
Grand Canyon Tech
Grand Canyon Tech
