SOURCE: code for sanyo tv phillips universal remote cl034
the code is 0506 Ihave the same remote and tv
SOURCE: Universal Remote Code for Dynex 20" TV/DVD
I just bought a 32" dynex lcd and saw that i couldn't program my two $5 ge remotes to work it. From reading in this forum and others I'm not the only one with the problem, I thought I was stuck with only the dynex remote. But the dynex website tells you how to get universal remotes to work,
It tells you to try the codes for Orion, Emerson, Memorex, Sansui, Sylvania, Zenith. The second orion code worked for me. both my ge remotes look and work the same but one uses a four digit code and the other uses a three digit code. I used 0135 on one and 135 on the other. There is a good chance that if you try the codes for the brands dynex lists you will find one that works. The 0135 or 135 might work for most dynex tv's.
If you have a ge remote and haven't programmed it for volume punch through you might try it. It allows the tv volume to be controlled using the ge remote even when it's set to something other than tv.
SOURCE: I need codes for a phillips tv and a phillips universal remote?
Hi michaeljlent,
There are a number of codes for your remote that correspond to Phillips TV models. They are:
002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
For your reference, here's a web address where all the codes for your remote are listed (along with programming instructions):
http://www.universal-remote.net/philipsmagnavox.html
I hope this helps - please let me know if I can be of any further assistance.
SOURCE: I need a universal remote
I can confirm that the 0441 code does indeed work for the Xbox 360 Universal Remote. I just programmed it and it works perfectly. Thanks to the person that first posted that code!
SOURCE: Codes for Phillips Universal remote clo35A
i have found the easiest way to get the codes to the clo35a model universal remote for phillips... go to the phillips website... here is the link that sends you directly to where you can get the codes. :)
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SRU3007/27&scy=US&slg=en#
