Check the base for a tip over safety switch. It needs to be pressed in. Can't find a manual for it as it appears to be an Amazon, Walmart special. Try it in another outlet, or put something else in that outlet that is known to work like your cellphone charger.
https://www.walmart.com/ip/Patton-Radiant-Heater/15126054
https://www.google.com/search?q=Patton+PRH11+manual
SOURCE: Patton space Heater Model # prh-5
check that the rocker switch inside isn't stuck, when the rocker swings it shuts the unit off. if it is full of dust it may be stuck. may just be bad.
SOURCE: I have a Patton Heater ( Brand New ) that was
One thing that I would do is to remove the back cover and make sure there are not any obstructions by fan motor or contacts for heating elements. Don't know where you are located but around here we have a real problem with mud dauber wasps getting in almost anywhere. I have had several power tools fail to work and upon disassembly have found nests. Thank you
SOURCE: Patton space heater power knob isn't working
First thing check see if you have power going to switch with a multimeter if you have one if there's power going in it switch need new switch probly you can us your multimeter to test switch on ohms
