SOURCE: WHIRLPOOL SUPER CAPACITY 465 (ELECTRIC) MODEL RF366PXGQ - F3 E0
Same thing happened to me about 1 month ago... Did you get some kind of power outage or lightning strike??? I am pretty sure the stove part works but the oven doesn't right?!?! It might be 2 things.. Either the temperature sensor inside the oven doesn't work or it's the control board (where the clock is). I tried to chaned teh temp sensor but it did not work. I then changed the Control Board and oven works again...
SOURCE: ER1 F2 error on Whirlpool Super Capacity 465 RF386PXE Oven
HOW DO YOU CLEAN SELF CLEANING OVEN SUPER CAPICITY 465
SOURCE: Whirlpool self cleaning oven, Super capacity 465, door will not close
I had the same FSE error which the whirpool web site advises that you will need to schedule a service appt to fix. Instead I leaded against the door while initiating the cleaning cycle and the door locks and oven cleans fine.
SOURCE: code fse1 comes up when a few minutes after pushing start to cle
F5 - E1
Self clean latch will not lock
1. If door latched:
2. If door not latched:
3. Measure door switch (door open = switch open small low voltage
terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light
contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control.
Press and hold any key for 1 minute to clear R failure code from memory.
F2 will appear. Press CANCEL and observe for 1 minute to ensure
operation is correct.
6. If failure remains, disconnect power and replace control.
SOURCE: whirlpool self cleaning oven 465 capacity model oven doesn't get
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
