SOURCE: Hi, I have just received
This may not help solve the problem but you don't mention having the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-CDP-CX355-CD-Players-manual/id/423dj280/t/2/
I
SOURCE: i wish to use the seagate hardrive to back up
Im not sure why you want Fat32 but with that old file system a partitition cant be larger than 32GB otherwise it wont let you format with Fat32. You can create as many partitions as you like maybe have some Fat32 and some NTFS if you like. Just typy in disk management where you normally do a search or run with XP and that will let you organise all of your partitions. Cheers and please vote
SOURCE: Brennan JB7 wont switch on after we had a power cut
The power supply may have a voltage missing or have gone bad. Worse is the motherboard fried. If you used a surge protector it may have done it's job. There are sacrificial parts called MOV's inside that sometimes explode or just open internally. That may need to be replaced.
