Televison & Video Logo
Russell Endriss Posted on Jan 19, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung UN55J6200AF that will no longer turn on. The TV would flicker when we would shut it off. Now the TV won't turn on at all.
Arnie Burke
Level 3:
  • Master 7,339 Answers
  • Posted on Jan 19, 2020
Arnie Burke
Master
Level 3:
Answers
7339
Questions
0
Helped
1822820
Points
21459
Time for new..cause it can cost as much to repair. Feb has sale on last yrs at walmart
1 Related Answer
Anonymous
  • 8 Answers
  • Posted on Apr 17, 2013
SOURCE: My 50" plasma Samsung tv shut off and won't turn back on. What could be wrong with it?
um make sure you ask a tv retailer before u ask us ok
Samsung TV - lights flicker and no standby light
Hi Ashley....Chances are your LED backlights need replacing, if you see a flash then black screen some of the lamps are shorted and the current draw is too high, and the protection circuitry is shutting down the inverter. You can check to be sure the main is working by testing the backlight on pin on the plug that goes from the main to power board, you need to see 3.3 vdc on that pin when you power the set on and it needs to stay at that voltage or you have main board issues
On un55j6200af there is sound no picture
Hello Loveleen, ask, does the TV turn on and do not give you an image or sound, or does it just not turn on?
As far as you know, you could have problems with the power supply board that feeds the rear lighting of the LCD panel and / or the main board, which governs the entire TV
I advise you, go to a specialized technical service
I hope you can solve the problem and soon you keep enjoying your Samsung TV
Greetings Franco Dosil
Hola Loveleen, pregunta, el televisor prende y no te de imagen ni sonido, o simplemente no enciende?
Por lo que cuentas, podr?as tener problemas en la placa de fuente de alimentaci?n que alimenta la iluminaci?n trasera del panel LCD y/ o la Placa principal, que gobierna a todo el televisor
Te aconsejo, te acerques a un servicio t?cnico especializado
Espero que puedas resolver el problema y pronto sigas disfrutando de tu TV Samsung
Saludos Franco Dosil
http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=US&CttFileID=6054697&CDCttType=UM&ModelType=C&ModelName=UN55J6200AFXZA&VPath=UM/201504/20150407095631744/ENG-US_NMATSCJ-1.103-0330.pdf
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Flickering
I would suggest to call Samsung to get the Plasma repair under manufacturers warranty. The flickering will not go away until the hardware failure is corrected.
Good Luck.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
