SOURCE: can't get my DAEWOO tv mod number GB20C5NT to tune in
Go to menu look for autoprogramming to lock in all channels you receive, you can adjust this with front buttons on tv ch- ch+ will let you scroll menu vol- & vol+ will let you adjust. ThankYou for trying FixYa. Have a Nice Day.
SOURCE: How to Auto tune remote control for 1993 Magnavox
I have an older RCA universal remote control and a magnavox tv from 1993. According to my universal remote user manual (which I found online) I punched in a three digit code: 062 that worked for me, for my 1993 Magnavox TV: hope this helps!
If not, here are some others to try from my RCA universal remote user manual for Magnavox tvs---
004, 006, 008, 019, 068,069,074,075,076,077,088,089,130,131,132,133,134,183,184.
SOURCE: I want to tune tv to digital l by remote
What is the brand name and model number to your tV?
SOURCE: I have a cybertec RM-79LE remote, and i dont knoe the code for my tv CHANGHONG
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
Try a reset to this set and then check. If it do not help, replace its power regulator [SMPS] board. It is faulty. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
