Televison & Video Logo
Jewelz Wilson Posted on Jan 18, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get into the hidden menu on a clear tech prison TV? CttvL15-ns
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Jun 08, 2021
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15002833
Points
237762
You have to enter its service menu to enter the hidden menus.
If you wish to get some details; check the site linked here. Pull up older posts.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter. See it in Webview with mobile or by desktop. Mobile View has no search box.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Hiteker 13" LED TV. How can I make my volume get louder on my 13" Hiteker tv.
There is no way to enhance what is already on the set. You could use headphone via the audio output jack, or use powered speakers. The newer ones have HDMI, so theoretically you could connect a theatre style sound bar.
https://www.google.com/search?q=hiteker+13%22+prison+tv+increase+volume
1helpful
Does clear tunes tv need batteries ?
If supplied by the prison it will not require batteries and definately will not have wifi or blue tooth.
I have a clear hiteker mp3 player that takes an sd card
Most have a tiny reset button.
https://www.google.com/search?q=hiteker+mp3+player+reset+button
This is for the tablet
Hard reset for hiteker model prison clear model?
Ask Me Fast https://www.askmefast.com > Hard_reset_for_hiteker_...
Press and hold Volume up and power at least 30 seconds to get the menu up. ... 4. When it process the request, go back to the previous menu and select restart for ...
Hiteker 13 inch clear TV wont power on
You will have to get the prison service to repair it. They are very specialized and only used in prisons.
Tv model NS-RC4NA-16
The NS-RC4NA-16 remote was included with a number of different Insignia TV models. The suffixes for the compatible TVs are available here: https://www.insigniaproducts.com/pdp/NS-RC4NA-16/9974105 . Insignia TV/DVD models with those suffixes are not compatible with the NS-RC4NA-16. A quick setup guide is available on the remote product page when you click on the Support & Downloads tab. The current link to this guide is https://files.bbystatic.com/EwxdCPik%2Fmi66olq9%2BGq6A%3D%3D/NS-RC4NA-16_14-1146_QSG_V1_ENG_FR_SP_Final_lr.pdf .
For more information on using the remote with your electronics, you might want to check the manual for a compatible television. One such TV is the NS-55D420NA16. That TV's support page is here: https://www.insigniaproducts.com/pdp/NS-55D420NA16/9003104 . The user manual for the TV is https://files.bbystatic.com/g9A76XeZ%2FqQsD64zxUp5Fw%3D%3D/NS-55D420NA16_Manual_EN.pdf . Note: the NS-RC4NA-16 is not a universal remote and can't be programmed to work with other electronics.
If you wish to program a universal remote to take over some of the functions of the NS-RC4NA-16, you can find a list of possible codes in the online guide for the TV or at http://www.insigniaproducts.com/remotecodes . To view the list on the TV, press Menu. Use the Left/Right arrows to navigate to Help. Press the Down arrow or Enter. Use the Up/Down arrows to navigate to Learn More. Press Enter. Again use the Up/Down arrows and go to "Remote Control Codes". Press Enter to see the list. Press Menu to go up in the menu system. Press Exit to leave the menus. At least on the NS-55D420NA16, you can do this navigation with the keys on the right side of the TV. Input becomes Enter. Volume +/- are the left/right arrows. The Channel Up/Down arrows are the Up/Down arrows. Menu is the topmost button.
I hope this helps. If you want to replace the NS-RC4NA-16, I've found it listed as available at Amazon.
How do i reprogram a clear digital LCD 13in clear tunes prison tv
you dont,you throw it away and get a flat screen hdtv for cheaper
Remote code for clear tech television model:ct tv L13-NS
I need internal adjustment code for a clear tech t.v
12 inch black square in center of the viewing screen when I turn tv on or switch stations
The black square is a text box for the deaf. You can turn it on and off with the closed captioning button on your remote or from the closed captioning section in your television's menu.
However if you are connecting a cable box or satellite tv receiver you would need to turn the text box off from its menu. There is often a hidden menu that needs to be accessed on the cable boxes and satellite tv receivers that can be reached by turning it off and then immediately pressing the menu button on the outside of it. For more details about a specific cable box or satellite tv receiver call your cable or satellite company.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
