SOURCE: Stuck in demo mode
When you are in STANDBY mode hold the menu button for a few seconds and a special menu should pop up. In this menu you should be able to set the clock, turn off or on the beep, and take your unit out of demo mode. Good luck.
-Andrew Hawkins
SOURCE: Sony HCDX1 STUCK IN DEMO MODE
I don't have a Sony HCDX1, so if this doesn't work, please do not rate me down.
Push the PLAY and STOP buttons (at the same time) and hold them for about ten seconds. This should get you out of DEMO mode.
Power the unit off, then back on. If the display now says LOCKED, then press the PLAY and STOP buttons (at the same time) again to unlock.
If this does work, please rate it Solved, so others can use this solution. Thanks!
SOURCE: Aiwa CDC-X504Mp stuck in demo mode
This recently happened to my Sony, maybe it will help u
If this cd player has a removal fascia then try..
Carefully inspect the the electrical contacts on the fasica and the cd player. If it has got dirt on them then CAREFULLY CAREFULLY clean with cotton swab dabbed in cleaning Alcohol.
SOURCE: DEMO MODE
Hello hoz685,
push volume up
and volume down buttons at the same time
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
When in Demo Mode, the console will go through a repeating lighting pattern. This
mode will only become active when the treadmill is plugged in, the main on/off switch
is turned on, and the safety key is not inserted into the console.
The Demo Mode was added to attract attention to the treadmill while it is on display. By
default, all treadmills with Demo Mode will come with it turned on. Demo Mode can be
turned off at any time.
Method #1 to switch from the Demo Mode:Press and hold the STOP button while inserting the safety key to enter the user
information mode.
Look in the Calories window. When Demo Mode is active, the letter 'd' will
appear.
Press the SPEED DOWN button to toggle the mode on and off.
Once the mode is set as desired, remove the safety key.
