Televison & Video Logo
Jocelyn Fallis Posted on Jan 18, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Easiest way to watch from my iPhone to the tv with no cables or adapters
ChinthakaJ
Level 3:
  • Master 943 Answers
  • Posted on Jan 18, 2020
ChinthakaJ
Master
Level 3:
Answers
943
Questions
Helped
301468
Points
2783
If the TV is a smart TV then, air drop or airn pin will work
Can I connect my iPad to tv so I can watch netfix
Connect With a Cable. By far, the simplest way to connect your iPhone or iPad to your TV is to use a cable like Apple's Digital AV Adapter, which connects your Apple device to your TV's HDMI port. You'll also need a standard HDMI cable-any one will do, so just buy the least expensive one you can find.Aug 23, 2017
How to Connect Your iPhone or iPad to Your TV ' PCMag.com
https://www.pcmag.com/article2/0,2817,2476651,00.asp
tip
Best Convert AVCHD video to iPhone 4 and iPhone 3G S on Mac OS
AVCHD to iPhone 4 converter Mac is best convert HD
videos, mts files to iPhone 4 supported MPEG-4/MP4,
H.264, M4V, MP3, AAC formats with powerful editing
functions like iMovie on mac.
Compared to iPhone 3G S, iPhone 4 is more powerful and simpler to use. With all these features, you’ll be able to watch comfortably HD movies on iPhone 4 display with more accurate colors.
With this amazing iPhone 4 and widely welcomed AVCHD videos. How about watching AVCHD movies with this magical smart phones. Yet, iPhone 4 has no support for AVCHD: mts or m2ts formats, then you will need to convert AVCHD to iPhone 4 supportable formats.
AVCHD to iPhone 4 Converter is a super software that well works with the new iPhone 4. It can convert or tranfer AVCHD video, like mts/m2ts or any other video format to iPhone 4 adaptable MPEG-4/MP4, H.264, M4V, MP3, AAC formats. With Mac AVCHD to iPhone 4 Converter, you have no limitation to enjoy your fantastic HD movies with this great applicaton.
Show you The easiest software to convert AVCHD directly to your iPhone/iPhone 4/iPhone 3G S.
on Jun 29, 2010 • Cameras
1helpful
Can I hook my tablet thru my wifi router or my cable box to stream internet TV on the big screen?
easiest way to stream to tv is with a cable. depending on the make of the tablet , you can buy hdmi micro cables to connect to tv. doing it wireless you will need a box plugged into the tv that has DNLA capability. both are available to buy.if you go for an android tv box they have that but also have XBMC which will allow you to watch any movie/tv programs/sports etc for free
How can I connect computer to tv
Most newer TVs have a VGA connector on the back with the rest of the connectors. This is generally the easiest connector to use. You can get a VGA cable from a local computer store to connect between your computer video connection and the TV. If you have an old VGA monitor you are no longer using, you may find that the old VGA cable is removable - as they are on some monitors.
Alternatively, you can connect to an HDMI connector on your laptop / PC to the TV's HDMI connector (they should be labeled) using a standard HDMI cable if you have such a connection available. This is the preferred method if you have this connector available on both devices.
Third alternative option is if your computer (or TV) have a DVI connector. This connector can be adapted to HDMI. As an example, if your computer uses a DVI connector, and your TV has an HDMI connector on the back you could buy a DVI -> HDMI cable, or just use a HDMI cable with a HDMI -> DVI adapter on one end.
Once you have connected to the TV in one of the above methods, you then have to use the TV remote and change the 'input source' until you see your computer.
Side note: If you are using a laptop, make sure that your external connector is enabled - for Windows users, right click on the desktop and choose properties then Display. (Windows 8 users, choose screen resolution in the same location).
Feb 24, 2015 • Netflix
2answers
How do I hook up my phone to tv
What type of phone?
IPhone? To do that with an IPhone you will need airplay and apple TV.
second solution is to buy an HDMI cable adapter for IPhone APPLe component AV cable.
Samsung Android? To do that you will need an All Share Cast Wirelles Hub.
Second solution an MHL adapter cable.
IPhone 5S mirroring
Yes it can. You have two options:
1. Connect an Apple TV to your TV and once you have both your Apple TV and iPhone on the same wireless network, you can do Airplay on your iPhone and mirror the display to your Apple TV (and thus your TV).
2. You can purchase a Lightning Digital AV Adapter and connect an HDMI cable from your TV to the adapter. This will also allow you to mirror your phone display to the TV.
1helpful
Do you need to use rf cable as well as scart connections ,with a dvd, sat. box and tv
Most modern entertainment electronics equipment have multiple ways of connecting. You just need to know how to connect them so it will be easiest to switch to vcr, dvd, satellite, cable, etc. You can use video/audio cables (yellow/red/white at both ends), RF cable, s-video cable, etc. You can use a combination of any or all of these, but the trick is to know how to switch from watching one to watching another.
Hope this helps!
Charging a refurbished iphone
Either plug cable into computer and phone or into wall adapter and phone.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
