Question about Sony Televison & Video
Sony KD-50X690E will not power on , power supply and main board have been replaced, still not powering on
Anonymous
SOURCE:
Anonymous
  • 66 Answers
SOURCE: My Westinghouse LVM-37w1 monitor has a weak power supply.
You can request parts at this email address: Parts@wde.com
You can also call this particular contact number: 866-839-5888
Posted on Jul 29, 2009
Jack South
  • 195 Answers
SOURCE: olevia 437-s11
Most likely the CCFL inverter has been the problem all along....
Posted on Oct 10, 2009
Chi Chu
  • 8457 Answers
SOURCE: Mitsubishi wd-62725. 8 power supply caps replaced
Replaced the FBT,that help the power too.
Posted on Jan 07, 2010
swoop611
Dave Sargent
  • 488 Answers
SOURCE: Gateway T2838 with Intel 4000812 motherboard
Check ALL your USB ports.. If any of the USB ports have shorted contacts or if the 5v rails are shorted to ground, the power supply WILL NOT switch on.. Also, if any of the items connected to the board have a supply rail grounded, again the board will not allow boot up. Unplug everything from the board and the drive power connectors too, except the power connector to the board and the front panel switches and try to switch on, if it still will not boot, check and recheck the USB ports and all power connectors, if it does, switch off and plug another item in, then switch on again. When you get to the item which prevents the board from switching on, thats where your problem lies. Dont forget, plug things back in one at a time, including the power plugs to the drives and try and power up between each item, and dont forget to power down after each item has been checked..
Posted on Mar 14, 2010
Oleg75
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Posted on Feb 07, 2011
MY PS3 WONT TURN BACK ON
Either power supply problem or blown surface mount fuse on the main board. First check all SMD fuses on the main board, and the fuse on the power supply board. If the power supply board fuse has blown replace it and try again, if it blows again you need to replace the power supply. If the power supply seems OK check all SMD fuses on the main board. There are 7 on the V3 and about a dozen on the V4 / V5 / V6.
Good luck...
May 30, 2010 | Sony Playstation 3 (PS3) Console
8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Feb 09, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
My sony kdf-42we655 has 7 flashing red blinks. please help.
Audio Protect (7 Flash): When DC voltage is detected at the speaker or
woofer outputs, IC3604/pin128 (TV-micro) goes low and IC3604 turns off
the main power (AC relay turns OFF).
Troubleshooting Tips:
1) Main cause of defective will be located on the KD-board
2) Confi rm KD-board is securely seated on the G2-board
3) Replace KD-board
Jun 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Picture quality poor
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
if not please follow these:
3) Replace KD-board
Thats a fairly complex Chassis. Unless youre really good at dissassemble and reassembly of small components, I would suggest a Sony authorized reapir tech do the repair.
Certainly, I can help you. I would recommend going to the following link and getting the service manual so he can see first hand disassembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
http://servicemanuals.vstore.ca/
DON'T FORGET TO RATE:
Aug 25, 2008 | Sony KDS-R50XBR1 50" HDTV
Hi again
yes 3x its lamp cover no doubt. ballast supply will give different error on this unit. this should help hdtv man
Diagnostic Item
Description
Number of times
STANDBY or LAMP LED
lamp flashes
Probable Cause Detected Symptoms
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Power/standby light flashes 7 times and the tv doesn't turn on
3) Replace KD-board
Jun 13, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Powers on but no sound & no picture
If you power the TV set ON, count how many times the light on the front blinks?
Is very unlikely you have to replace the whole main board.
Feb 07, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Sony Wega 42" LCD HDTV
I've been trying to find th thermal fuse on a 42we655 for like 3 weeks...It's not under the lamp...Any one know where it is?
Thanks
Aug 31, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
29 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
