Question about The Office Equipment & Supplies
Power recliner will open part way and stop, if I disconnect the 5pin plug and wait then plug back in it will work again for a few seconds then I have to repeat process
Anonymous
SOURCE:
Anonymous
  • 203 Answers
SOURCE: Turns off after a few seconds
The unit is going in to shutdown. There is a short in the unit. My guess would be the HOT and or Flyback are bad.
Posted on Jun 08, 2007
Anonymous
  • 4 Answers
SOURCE: 2 wire Router is not working
I had a similar problem when the power went out and the router got hooped, the solution was to UNPLUG the power CONVERTER from the wall and wait ten minutes before plugging it in again.
Posted on Jan 04, 2009
Anonymous
  • 3 Answers
SOURCE: Power window comes up intermittently
I had the same problem. It was a bent rod on the regulator, which burned out the motor. Easiest way is to switch out the whole assembly, the motor and the regulator. Mine is working just fine now. I am a female and was able to switch it out just fine i just had to have someone else hold the window in the right positions to get to the bolts on the window.
Posted on Apr 20, 2009
projdoc
jasbo
  • 2239 Answers
SOURCE: proxima ultralight x350 runs fine for few minutes,
lamp is on it's way out. proxima no longer carries the lamp, but try to find it online. part # sp-lamp-027
Posted on Sep 16, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Our GE sss25kfmdww "freezes up" and then stops refrigerating
Most times on that model the defrost heater and defrost thermostat will need to be replaced. The timer is built into the mother board and for some reason they are not the most likely reason. The defrost heater has a glass tube around the element and easy to spot if burned out. If you replace one part you should replace both. Now is a good time for you to do a little reading about your model. I will give you a link to the service manual and a page with a tech sheet, Sea Breeze
Posted on Dec 19, 2009
Why doesn't power button work?
You will have to turn that bulky recliner on its side or even upside down to get access underneath. Inspection may reveal that the real problem is damaged or disconnected wiring but it may turn out that the switch is defective and will have to be replaced.
Sep 06, 2015 | Furniture
Printer does not print
Instructions
    • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
    • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
    • 3 Release "Stop/Reset" while holding down the "Power" button.
    • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
    • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
    • 6 Push the "Power" button, then lift the MX310 cover open.
    • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
    • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Jul 23, 2014 | Canon PIXMA MX310 All-In-One Printer
Power (driver) seat won't recline; everything else works
I would first disconnect and recommended checking if something is tangled in the track and make sure plugs in good
Nov 22, 2013 | 1998 Toyota Avalon
Ink system failure error 0xc05d0281. can not print
Solution one: Reset the product
1. Without turning off the product, disconnect the USB cable from the rear of the product
2. Remove the cartridges from the product.
3. Wait until a message to insert the cartridges displays. If you do not see a message within a few minutes, skip to the next step.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button
7. Reinsert the cartridges, and then close any open doors on the product
8. If you receive a prompt to print a calibration page, do so.
9. If you disconnected the USB cable, reconnect it to the rear of the product.
10. Try printing again.
11. if it does not work connect the printer directly to the walloutlet. as well as try with a different walloutlet.
12. Try with different set of ink cartridges.
13.if still it does not work then Unplug the power cord from the product, and wait 20 seconds. Press and hold # and 3 while plugging in the power cord to the product. Release the buttons after the product starts up. The product will now be reset to factory defaults.
14. still if it does not work then the printer hardware has gone bad. Service the Product.
Nov 08, 2013 | HP Photosmart C7180 All-In-One InkJet...
0xc18a0206 error
1. Without turning off the product, disconnect the USB cable from the rear of the product.
5. Wait 60 seconds
11. or else try with a different ink cartridges.
12. do a reset :
13. Service the product
Apr 29, 2013 | HP Photosmart C7180 All-In-One InkJet...
0xc05d1281
Wait 60 seconds.
Try printing again.
Try with a different set of ink cartridges...
Try doing a reset : Unplug the power cord from the product, and wait 20 seconds.
Press and hold # and 6 while plugging in the power cord to the product.
Hope this helps for you
Oct 31, 2012 | HEWLETT-PACKARD Photosmart C7280...
Sliding doors on 2005 odyssey work for 3 times then stop
Light on , DTC'S - diagnostic trouble codes stored in the power sliding door control module . Have a qualified repair shop check it out .
Jan 03, 2018 | 2005 Honda Odyssey EX
Hp p1005 stopped working
Printer switching on?.Might be power supply failed, replace Power supply board.if you are tech guy..Open left,right & back doors. Check input fuse.. if fuse open replace with same rated fuse, give power, check.. if again fuse is open replace power supply board. if its OK wait few minutes & confirm.. fix it back..
Nov 28, 2011 | HP LASERJET P1005 Printer
I have an error 5200 The green light flashes and the orange alarm flashes.does not print. have tried unplugging the printer. then plugging it back in. Does not work.
This will work
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Sep 17, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
Can't get router to work after disconnection.
Try setting it up as follows, if its not working come back on and let us know.
Plug in the modem power.
Plug in the router power.
Plug in one ethernet cable from the modem to the internet port or WAN port of the router.
If not wireless, plug a second ethernet cable into the "1" port of the router and the other end of that cable to the computers LAN or ethernet port.
Attempt to get on a website.
If this is unsuccessful, restart the modem by unplugging the power cord from the modem, wait 15 seconds, then plug it back in.
Unplug the router, wait for 15 seconds then plug it back in.
Still doesn't work?
On your computer, hit Start>Run>type cmd in the text box and hit enter.
A window will open up with a cursor.
Type ipconfig /release
Hit enter.
Type ipconfig /renew
Hit enter.
Try once again to access a website. If this is unsuccessful, return this site and let us know what steps you have tried.
Hope this helps.
Mar 12, 2009 | Computers & Internet
44 people viewed this question
Top The Office Equipment & Supplies Experts
Thomas F. Schneider
Keith Love
James Cagle
James Cagle
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
