Question about Makita Air Tools & Compressors
Hi Have a makita GN900 nail gun and it will only fire when i push on the fuel cell cover any ideas ??
Anonymous
SOURCE:
Anonymous
  • 104 Answers
SOURCE: paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Posted on Oct 22, 2008
Chuck Nelson
  • 24 Answers
SOURCE: Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Posted on Apr 14, 2009
Joe Hogan
  • 10865 Answers
SOURCE: Bostitch nail gun loss of pressure, won't fire nail
Hello. I can help you. The nail gun you have uses 18 gauge brads. I would use only original Bostitch 18 gauge.
The one MM of difference you mention is the reason why you do not have the pressure you did have. Get rid of those 31MM brads and get the 18 gauge. Home Depot carries the Bostitch line. I would go there or to homedepot.com
Posted on May 20, 2009
Robert Sabino
  • 142 Answers
SOURCE: Gun's drive rod not retracting back after firing a nail
you need a top end rebuild kit
Posted on Jan 05, 2010
Anonymous
  • 14 Answers
SOURCE: gun does not fire every time
When you cleaned it, you may have pinched the large brown o-ring that is around the fan. Take gun apart again and reassemble. before you place the orange head valve cover on, press the nose of the gun into a wood surface and assure the o-ring goes into chamber unrestricted. Basically, the aluminum fingers of the cylinder should not pinch off the o-ring.
Posted on Jan 10, 2010
Testimonial: "I ordered a rebuild kit and this took care of the problem!(spark plug, new filter o ring etc) Thanks for all the assistance!!!"
My makita nail gun was firing 3 nails at once. Now its not firing any and it appears to have come apart at the casing. Help!!!!
yep they do that
extreme care needed to take the gun apart
especially if the rail of nails seperate in the tool
or drum type dispenser if fitted
choose your model see if the user manual helps in repairing
http://powertool.manualsonline.com/manuals/mfg/makita/makita_nail_gun_product_list.html
May 10, 2016 | Makita Air Tools & Compressors
Nailer wont advance the nails then it shoots blank
Try ez test to check for proper operation. Remove nails and air supply, point nose of gun up then down again. The driver should not move from the top of cylinder position. If driver is moving up then down replace the driver oring. If driver oring seems ok then connect air supply and bump fire the nailer without nails against soft wood and door open so that you can see the driver and feeder moving. Bump fire the gun and make sure that the driver is moving all the way back up to top of cylinder and the feeder is moving rapidly back and forward. If movement seems ok then hold the nose down on soft wood and depress and hold the trigger. This will fire the gun but driver will stay at the bottom position and not return until you release the trigger or lift the gun. When holding the gun with the driver down position, no air should leak out the top or bottom of the gun. If air leaks out bottom, replace lower bumper, if air leaks out the top replace the upper bumper. Good luck
Mar 19, 2015 | Porter Cable Coil Roofing Nailer
Makita gn900 gas nailer, trigger is sticking sometimes and I have to push prongs in to release, can anyone help..?
Wild guess. You've been using a long time. I'd try a little WD-40.
NO help? may need to replace trigger mechanism.
Mar 06, 2015 | Makita Air Tools & Compressors
Makita gn900 nail gun wont fire on half full gas cell
Hi... mine had the same problem when I bought it cheap second-hand. I made a spacer out of a washer that slips over the gas stem adapter and so far 100% fire rate. It holds the adapter closer to the cartridge nozzle and opens the valve that releases the gas when the trigger is pulled. Too easy! Good luck.
Sep 08, 2011 | Makita Tools & Hardware - Others
Nail not firing, battery charged, fuel cell good,
When you took it apart to clean it, you may have piched off the large brown o-ring on the head valve. To check this, take the orange head valve cover off and push the gun downard onto a piece of wood as if firing it. Watch the o-ring to see if it clears all the metal fingers around the fan.
Dec 20, 2009 | RTO PasLode 900420 Impulse Framing Nailer
Apr 11, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Jammed makita an923 nail gun
On most all nailguns when the trigger is activated air pressure is released from the headvalve causing the headvalve to open and fire the piston. If air leaks through the headvalve orings or through the headgasket port to headvalve, it will not fire. Try applying light grease to headvalve orings and make sure that headgasket is sealing around vent hole. If it fires then replace orings in headvalve for long term repair. Secondary problem is worn safety parts and trigger or trigger pin. If these parts are worn the trigger will not push the trigger valve pin all the way in when you bump fire the gun. With air supply disconnected, apply pressure to safety while depressing the trigger and check thet the pin is moving all the way into the trigger valve. Adjust or replace as necessary. Enjoy
Sep 13, 2008 | Air Tools & Compressors
Nail Guns Safety problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Aug 27, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Air Tools & Compressors Logo
27 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
Dennis Gaebel
Dennis Gaebel
Level 1 Expert
Joe Garcia
Joe Garcia
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
