Question about Samsung Televison & Video
I have a Samsung 48 curved TV which has suddenly dimmed, i.e. the colours and picture on the screen are fine, but it's dull and pretty dark - even on full brightness
    Top Expert:
  • Samsung Master
  • 10,764 Answers
If cant change in picture settings then bad board
Posted on Jan 18, 2020
Testimonial: "Tehnician is saying it's the actual LED panel that's faulty, but there are no damp spots or lines, just overall dim picture. Do you think it could just be a board that needs replacing? To replace the entire screen is same price as new tv :-( Should I get a second opinion from another technician maybe?"
Anonymous
SOURCE:
Anonymous
  • 3130 Answers
SOURCE: tv still dim after adjusting
sounds like you may have gotten a pwer surge and blew out the regulator in the set. If you know how to trouble shoot regulator curcuitds then it could be as simple as the str type regulator. If you dont then open the set and see what module the set has it would start with a 9-something as it should be inside the back cover and then contact http://www.tristatemodule.com and see what they charge to repair the entire pcb or the exchange of the module. As Zenith sets are made to be repaired in house by quilifyed repair stations IN hOUSE. Good luck to ya.
Posted on Apr 27, 2006
Anonymous
  • 188 Answers
SOURCE: Dull screen lighting
There may be a bios setting to adjust the screen brightness or a utility installed in Windows - What brand and model laptop is it???
Posted on Jan 12, 2008
Anonymous
SOURCE: Fading picture that looks dark and dull on a 42" Samsung DLP tv.
You need a new lamp...
Posted on Feb 27, 2009
mahesh patel
  • 197 Answers
SOURCE: Samsung 46" LCD picture dark at one side of the screen
bad panel
Posted on Jun 07, 2009
SOURCE: Dark Screen even when i adjust the 'brightness' tab?
check the power settings on te unit, if it is set to default for the backlight, possible that your LCD's backlight is not powering up properly on the unit or LCD's backlight needs replacement.
Posted on Jun 04, 2010
Our samsung smart tv screen goes dark at nightfall. We have to open the blinds to let light in to get the screen normal again. Is there some kind of setting I can set to stop this from happening?
It is there. Designed to have a brighter picture during the day and dim it in the evening. Have different names for the feature.
Check your manual out for it.
Sep 30, 2016 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
The picture has suddenly gone dark. We can still see the picture, however it is really dark. We tried shutting it completely down and unplugging and restarting it. We tried to adjust the color via the...
The tv LED light on the tv front bazel frame face have the word "LAMP" light up or blinking?Yes.The tv projection lamp been inside this tv like 1 1/2 or 2 years already,tv used it everydays like 4 or 5 hrs daily?Yes.Than the tv projection lamp life are over,that why it dim picture tv now must have it tv projection lamp to be replaced.
Jun 12, 2011 | Samsung SP50L6HX 50" DLP HDTV
Leapster 2 screen to dull to see
The leapster 2 screen is so dull you can hardly see the writing and programs. Very dark in colour. You can see colour arounf the edge of screen but the darkness overpowers the screen.
Jun 06, 2010 | LeapFrog Leapster 2 Learning System
Out of focus doble colours
These sets have several common problems which are listed below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find the fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Samsung HCM4215W 42" Rear Projection...
Picture has double exposure as well as curved, color also is distorted with pink at the top of screen. It is on a good surge protector. It was fine last night and just started it this evening when we...
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • No Audio/Video - TV makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 06, 2010 | Samsung PCN5425R 54" Rear Projection...
Jvc av-48wp74 48 in widescreen green projector problem
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 27, 2009 | JVC AV-48WP74 48" Rear Projection...
Suddenly all of a sudden
I have a JVC AV48WPT4 48 Inches. Have perfect picture but fine retrace lines on the screen.
Can you tell me what could cause it?
Thank you.
Apr 21, 2008 | JVC AV-48WP74 48" Rear Projection...
Televison & Video Logo
29 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
