Question about Lands Phones
Does anyone have an idea I have old Phillips tbx1000 PABX.problem is operator cobsole stopped working.can i connect a single line set to be operator and how so that outside lines can be routed again
Anonymous
SOURCE:
Anonymous
SOURCE: Phones stopped working
I don't have a solution, but I can say that my phone does exactly the same thing and I know for a fact it isn't the line because I'm using another phone on that line right now.
Posted on Nov 29, 2006
jdbouncer
James Peters
  • 72 Answers
SOURCE: Phillips 42in plasma lines ocross screen
Are the solid horizontal black lines or colored lines. If colored lines there is a posibility that your Y-main, and upper and lower Y-buffers are bad. If black you have a bad plasma panel.
Posted on Apr 08, 2008
Anonymous
SOURCE: JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Posted on Oct 05, 2008
Anonymous
  • 39 Answers
SOURCE: No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
Posted on Mar 20, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: Poulan sm132 fuel line routing
One fuel line (the on with the filter in the end of it) comes out of the fuel tank and goes to the bottom fitting on the carburator. The other hose comes out of the tank and goes to the bottom fitting on the primer bulb. A third section of fuel line goes from the top fitting on the primer bulb to the top fitting on the carburator. Hope this helped and best wishes.
Posted on Aug 27, 2009
Uniden troubleshooting
was the old phone connected to a Private Automatic Branch Exchange P.A.B.X like for example a comander system if so the new phone would have to be a PABX type phone extention type. I suspect the Uniden phone is not compatible with the PABX extension socket.
http://www.excitingip.net/291/ata-analog-telephony-adapter/
http://www.kosmaz.com/ata.htm
http://www.cisco.com/c/en/us/products/collateral/unified-communications/ata-186-analog-telephone-adaptor/product_data_sheet09186a008007cd72.html
I do not know what phone system you are using you might want to find out the model number of your PBX device and research if it uses VOIP = I can only guess that this is the situation
Sep 01, 2014 | Radio Communications
Phillips DVD recorder connection issue?
SCART is designed to carry analogue standard definition content. So if the input signal is high def. it will distort.
Jun 09, 2014 | Philips Televison & Video
Hi Gooday! Im a Panasonic pabx technician...i had a problem with our current project pabx system the CO card or trunkCard always hung and all line always busy...whst is the posible problem of my...
Two possibilities. The C.O. is not sending a disconnect or the timing needs to be set. It's a C.O. trunk time you adjust first and if that doesn't work, call the telco. We have hardware to simulate disconnect supervision if the phone company (or PBX extension like a Panasonic) can't provide it. We have to use them on elevator extensions.
Carl
May 24, 2011 | Panasonic Lands Phones
My original remote with this model stopped working several months ago.I bought a phillips universal remote and that worked fine for several months and that stopped working.I bought a new Phillips...
The first possibility is that the new remote control is a dud out of the box. It can happen. Another possibility is that the remote sensor in the TV has failed. Then the remote is transmitting, but it's not being picked up by the TV. (The lights are on but there's nobody home.) If you can, return the new remote to the store and exchange it. Then, if the set still doesn't respond, you'll need to replace the remote sensor.
Jan 02, 2011 | Sylvania 4819LT 19" TV
HP j3608 Can not get fax to answer on combined phone line with fax I have set for FAX & single ring any ideas?
If you have checked the programming to make it Auto Answer and have the Ring set to one then it may not be connected to the phone line. Does it send OK? If it does not send then it may not be connected to the phone line. Check the plugs on the phone wire and the sockets on the machine and in the wall to see if the connectors are straight.
Another question, what type of phone line do you use? If you have a digital phone system your fax may not work on the line you have in the office. It requires an analog POTs (Plain Old Phone) line.
Jul 14, 2010 | HP Office Equipment & Supplies
Call divert not working
normally this feature is enabled by the phone co. this allows you to activate and de activate the call divert
so call the phone co and ask them is this feature enabled on your line and what are the codes you use to turn feature on/off
i am referring of course to a single business line and not a pabx environment...i hope this helps in some small way
Dec 23, 2008 | Alcatel Lands Phones
Motorola D210 Cordless Phone
hi i have problem with motorola 210 cordless phone ta base is ok but ta single handset screen shows unregister this why is not working.
Sep 28, 2008 | Lands Phones
Unable to connect to Digital satellite receiver
I threw the mitsubishi VHS recorder under a bus, just like ' YOU CHANGE , CHANGE ,CHANGE FOR MY SAKE'S' grandma, and invested in a new DVD recorder, 2 yr g'tee and latest tech. GODDAM A--- well old grandma and anyone or anything else that gets in my manical lust for power. CHANGE EVERYTHING FOR ME, ME ME, ER UM US US US.
THANKS FOR YOUR TIME GUYS.
Aug 20, 2008 | Mitsubishi Televison & Video
Phillips 18 year old televison
Hi Kathy,
If you are referring to a single bright line left to right, then I would suspect that your TV have a vertical output failure. Depending on the particular model, this could be a single IC or a transistor pair. This is relatively an easy job and component replacement should be readily available. Since the unit will be opened for confirmatory diagnosis and eventually parts replacement, may I also suggest that you ask the service personnel who's going to do the job to likewise replace the vertical capacitor. They have a tendency to dry out after some time. It is the biggest of the lot (of capacitors in the vertical section). Parts cost would also be relatively low.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 08, 2008 | Televison & Video
Lands Phones Logo
37 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
