SOURCE: my sentry brand safe is
my bars are engaged my key pad fell in aand i lost keys who should i talk to?
SOURCE: driver's door won't open
The problem is the door latch, you can use sawsall to cut the door stricker off this way you can open the door and replace the latch
SOURCE: cant get the back door open on 2000 tracker the
Reach up and pull the door handle down then unlock the door.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
SOURCE: gordon item#45891 digital safe, lost code the door is open
there is red button on the inside of the door (hinge side) press this , then key in a new code
