Here is a nice YOUTUBE that describes the steps to replace your screen... While it is a 8" Touch Screen Digitizer replacement process, the steps should be the same:
Amazon.com, Inc.
Rating: 2.3 - 46 reviews
Ellipsis 8 Tablet 16GB, Wi-Fi + Verizon 4G LTE, 8in - BlackNetwork Type: CDMA .... After only one charge, I don't find either inferior to other android devices I've used. .... the worst mini tablet possible they would be well advised to model it after this ... Check out these pages to see more: verizon tablet, case eclipse 7, verizon ...
Amazon.com, Inc.
Rating: 2.3 - 178 reviews
See all Open-Box & Preowned offers from Amazon Warehouse Deals. ... Ellipsis 7Tablet 8GB, Wi-Fi + Verizon 4G LTE, 7in - BlackNetwork Type: CDMA ... Learn More; ASIN: B00GJ3MF9Q; Item model number: Ellipsis 7; Average ... it...guess they don'twant people to know the truth about their first foray into the tablet market.
Hi, you need to perform a factory reset, follow these instructions:
Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
"Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
Use the volume buttons to move up and down through selection in this menu.
Using the volume down button, scroll down to "Wipe data/factory reset"
Tap Power hard key to select option.
Scroll down to select "Yes, delete all user data".
Tap the power button to select. Wiping and formatting data will take a few minutes.
You will return back to the Android recovery screen menu.
Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
