Question about Watches
Why does Hplus app not record times when running in minutes and seconds, it only gives time in minutes without seconds so is not accurate.
My HPlus watch is not charging, I have some time on my warranty, but not sure if this covered, what step do I take next.
try checking with the store where you purchased it , or the manufacturer directly.
Apr 01, 2018 | Watches
How do you change the time on the HPlus watch?
Try Googling (HPlus)(model)(manual) without parens to get instructions.
Nov 05, 2017 | The Watches
Second hand not moving
If the Chronograph is running, the second hand may be paused as on of your dials is recording seconds instead of the larger second hand. You shouldn't be running the chronograph timing all the time.
Jan 13, 2016 | Watches
Eve mon crois watch 9441-FS instruktionbook
Watch controls (eve mon crois) TL= top left button TR= top right button BL= bottom left button BR= bottom right button TL= toggle light TR= view date BR= view alarm time BL= toggle options 1 press --> stopwatch 2 press --> change alarm time 3 press --> change digital time 4 press --> return to regular view (When on option) Stopwatch: TR= stop/start stopwatch BR= reset stopwatch time BL= next option Change alarm time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Change digital time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Normal view: (controls shown at top) In normal view when: TR is held down --> BR= toggle alarm on/off TL is held down --> BL= toggle through days BR is held down --> TR= toggle alarm on/off (for accurate digital time go to the option of change digital time and set it to the next minute from when you are make sure that the the counting seconds are flashing. When the next minute comes press TR this will reset the seconds to '00' without changing the minute and you will now be accurate to the clock you used by less than a second) I got this info through a long time of just experimenting with the buttons, still working on finding a way of changing the date but for now this should be enough to get you by with the watch. Hope this helps somebody :)
Jan 30, 2014 | Watches
Watch erratic. Slows suddenly between days of working well.
Sounds like a failing battery to me. Its very common for a watch to loose time when battery needs to be changed.
Jan 09, 2010 | Timex Watches
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Jan 09, 2009 | Bulova Watch
The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Dec 20, 2008 | Watches
How do I use my watch???
I also own a PRS200. The two buttons on the right and top two subdials are for the chronometer function.
The top right button starts and stops the chronometer function: First press starts the chrono. Second press freezes/stops it, so you can record your time. Third press resets the chrono.
The bottom button is for the lap function: on the first press, it freezes the chrono in order for you to be able to record your "lap time", but keeps the chrono running in the background (you don't see this, it's the movement that does this mechanically). When you press it a second time, it jumps back to the running chrono time. You can then press it again to get another lap time, and so on...
In chrono mode, the top right subdial shows the milliseconds, the second hand shows the seconds, and the top left subdial shows the minutes (up to 30 minutes).
Feb 23, 2008 | Tissot PRS 200 Wrist Watch
Rolex ad Daytona 1992 replica
The advice given here is accurate to a degree. When wound, a rolex daytona IS running. However, it is the running seconds hand in the small sub-dial that is actually running. In the earlier Daytonas, this sub-dial was at the 9 o'clock position on the dial, (pre-2001 series daytonas). The later daytonas, from 2001 on, use the seconds at 6 position for counting seconds. The main sweeping second hand on the watch dial will NOT start until activated by the pusher at the 2 position. That pusher needs to be unscrewed and then pushed to start the large sweeping second hand. This action, in turn, starts the remaining 2 sub-dials in motion, counting minutes and hours. To stop the chronograph function, you push the pusher @ the 2 position again, to stop the sub-dial hands from counting, and then push the pusher @ the 4 position to re-set the dials to their "straight up position". This stops the chrono's function, until it is needed again, BUT the main running seconds, (at either the 9 or 6 sub-dial position, depending on the year series of the daytona) will continue to run, thus keeping accurate time.  Hope this gives you a better idea of how the timekeeping of the chronograph function on a Daytona works. So, to start your seconds running you need to start the chrono function by pressing the pusher at the 2 position. That will allow you to see the large sweeping second hand I think you're referring to here. Hope this has helped.
Doug
Jan 11, 2008 | Rolex Daytona 116520 Wrist Watch
Watches Logo
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
