Question about Garden
Yard Machine snow blower won't start - Garden
  • 1,690 Answers
Make sure you are using new gas, check the spark as often the induction coil goes bad and needs replacing.
Posted on Jan 16, 2020
Anonymous
SOURCE:
What grade of oil for a 8.5 bourse snow blower
5w30 for cold weather. Anything thicker (higher numbers) will be too difficult to start on a cold morning. Oil will be too thick
Aug 17, 2014 | Yard Machines 26" 208cc Two Stage Snow...
Yard machine snow blower
be sure to check in blower housing (the round part) that impeller isnt frozen at the bottom
can also take off belt guard (2bolts) and check to be sure belts are on correctly
Dec 18, 2013 | Yard Machines 28" Two-Stage Snowthrower
Accidently hit stick in side yard. now wont throw snow. Everything else seems good
blower might still work but gear case that runs auger is shot or you sheared the shear pins in auger
Dec 17, 2013 | Yard Machines 31AS63EE700 208cc Gas 24-in...
My cub cadet 221 cranks won't start
Clean your carb, if you have not stored it correctly you have a dirty carb now. Carb could be gummed up.
Feb 17, 2013 | Cub Cadet Snow Blowers. 21 in....
My yardmachine snow blower 8hp auger won't turn. I replaced the cable and belt but it still won't turn. What else could be wrong?
Check the auger shear pins replace if necessary with correct parts(not regular bolts).
If auger and the impeller are not turning your cable is out of adjustment.
If only the auger doesn't turn, and the shear pins are ok then the brass/bronze gear has shredded which is why proper shear pins must be used. Donyboy73 on youtube show how to replace that gear on an older but similar MTD affiliated blower.
Feb 16, 2013 | Yard Machines 24" 208cc Two Stage Snow...
I have a yard machine 5hp 22" snow blower. The
TRY PUTTING SOME SEA FOAM IN YOUR GAS AND LET IT RUN AWHILE MAY HELP.
Sep 25, 2017 | Yard Machines Garden
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
