Question about Garden
Where do you fill the oil on a PTO K connect from a 1100XC kabota
    Sergeant:
  • 278 Answers
Https://www.youtube.com/watch?v=1pAYB4y9nqg
https://www.youtube.com/watch?v=btD5taYfmqs
Posted on Jan 31, 2020
2 Suggested Answers
Anonymous
SOURCE:
Danny Kuhlmann
  • 1443 Answers
SOURCE: I have a kabota tractor and the Pto will not engage on the bush hog
pto is on the tractor, not on the bush hog, if it won't engage you have pto problems on tractor, needs to be serviced
Posted on Dec 01, 2015
I have a grasshopper 722D mower that dies when on side slope with discharge chute on uphill side. Both fuel filters have been replaced by dealer with Kabota filters, but the problem has not been fixed
what MAKE motor do you have .? Many tecmuseh motors have an oil pressure switch that kills the motor if it is on the side of a hill and oil does not keep up pressure
May 13, 2018 | Garden
I have a zd21 kabota mower. what kind of oil ges in the tube behind the right side fender? its says oil but doesnt specify weather its hydraulic or motor oil
engine oil goes in the engine which will be at the dipstick hole or filler cap on the engine
anywhere else on the mower will be hydraulic oil
Apr 28, 2016 | Garden
Dec 01, 2015 | Kubota T1600H Mower tractor
needs to be serviced, unless you are a mechanic
Dec 01, 2015 | Garden
Kabota GR2100
Is it plug or valve? Remove valve.
Mar 22, 2014 | Cub Cadet 50 in. 23 HP Kawasaki Twin...
Wheelhorse 314 engines dies when pto is engaged
I am assuming you have a manual PTO clutch since you did not mention a PTO switch. The starting circuit generally is a series of switches wired in line (series) with each other. You have bypassed the seat but there is usually a switch for neutral, PTO, oil level, and clutch. You will need to trace the wires from one to the other to find the problem. If the seat has a double switch (3 or 4 wires) it is wired through the PTO switch which may be a double switch to short out the ignition so that part of the circuit should stay open to operate. If the oil level is ok and the oil has been changed as recommended you may better consult a Wheelhorse service person. Bypassing the switches is for testing only! I DO NOT RECOMEND LEAVING ANY SAFETY SWITCH BYPASSED. Any defective or out of adjustment switch should be replaced or corrected.
May 05, 2013 | Garden
Does the electric pto clutch on a model 1024 have oil inside of it
Hi, the pto should be dry, the oil would have come from the engine somewhere. Most likely the main crankshaft seal. Regards Phil.
Jul 05, 2012 | Oregon Scientific Electric PTO Clutch for...
Briggs&straton all the oil leaked out from under the engine. the engine oil
hi there donald77
provided you have not got any cracks in the sump plate and the sump plate bolts are tight
sounds like you have a worn out pto seal ( please check pto for bend or wobble ) as this could have caused this from hitting something solid
it it is bent have it straightened before proceeding
remove the blade carrier and hub and key - clean up the pto with emery tape , drain oil , use a straight shaft flat blade screwdriver and lever the seal out of position
obtain a new seal place some thin plastic sheet ( from say a thin walled plastic container )
cut into a size that you can wrap around pto , then slide the seal over it up to the opening ,
the drive the seal into the housing squarely until the seal is flush with the housing ( on a non stepped pto ) 7/8 shaft
but on a stepped pto 25 mm drive it in further until its about 3 mm below the housing
reassemble and refill with oil
cheers hope it helps
pauly46
May 30, 2011 | Garden
PTO making noise when engaged in forward drive
It's 90 weight gear oil but most likely the output shaft seal has been gone for a consdierable amount of time and has leaked out and is just now making noise, they don't normally make noise right away after the oil runs out. put oil up to the plug fill hole and watch if it runs out the shaft seal if it does then it will have ti be repaiered.
Nov 13, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Garden Logo
27 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
