Computers & Internet Logo
stephen hart Posted on Jan 16, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Windows 10 PC now has a locked keyboard. I may have hit shift multiple times. I have unplugged, deleted keyboard device and restarted, ensured the filter key is off
Larry Ng
Level 3:
Top Expert:
  • The Master 14,563 Answers
  • Posted on Jan 18, 2020
Larry Ng
The Master
Level 3:
Top Expert:
Answers
14563
Questions
0
Helped
3274035
Points
66461
No pc STATED,
why leave out the one key fact like that?
name of PC and model. first. ok"?
pretend the helper can't see you nor it..
5 Related Answers
colliewob
David
  • 781 Answers
  • Posted on Jul 24, 2008
SOURCE: Need to disable a key on my keyboard
check your keyboard in
Start/settings/control panel/keyboard right click open check what options available you may be able to stop key working
Anonymous
  • 136 Answers
  • Posted on Oct 27, 2008
SOURCE: emachine laptop Fn key locked
I think the only solution is to phisically remove the key from the keyboard - VERY gently, in order not to break or send flying the pieces to which the key is attached. The little rubber button underneath might be squished below those pieces.
marsoblivion
  • Posted on Dec 02, 2008
SOURCE: "page down" lock light on keyboard..don't know how to unlock (?)
Scroll Lock button. =]
Anonymous
  • 203 Answers
  • Posted on Feb 25, 2009
SOURCE: I accidently locked my keyboard while holding down the shift key,
it sounds like you have sticky keys on.
this would come on by pressing the shift key 5 times.
press any two keys at the same time and the control panel will come up.
Anonymous
  • Posted on Nov 12, 2009
SOURCE: Keyboard and touch pad will not work
The HP50 and HP60 laptops both have a lock button I just discovered by tripping over it today. Couldn't find a description of it in the printed or onboard manuals. This button is in addition to the overall computer lock function key (f6) that is well described. This keyboard/touchpad (k/t) lock button is obvious when pointed out, but less so when those items are already locked out by casual hand motion. The button is located just above the touchpad and is embedded in the border trim of the keypad. It toggles access to your k/t. It has a little indicator light so one doesn't miss it, but it is pretty low-key, if you forgive the pun. Designers can be a little too cool sometimes!
tip
Windows xp keyboard tips
and also
and
Windows system key combinations
  • F1: Help
  • CTRL+ESC: Open Start menu
  • ALT+TAB: Switch between open programs
  • ALT+F4: Quit program
  • SHIFT+DELETE: Delete item permanently
  • Windows Logo+L: Lock the computer (without using CTRL+ALT+DELETE)
Windows program key combinations
  • CTRL+C: Copy
  • CTRL+X: Cut
  • CTRL+V: Paste
  • CTRL+Z: Undo
  • CTRL+B: Bold
  • CTRL+U: Underline
  • CTRL+I: Italic
Mouse click/keyboard modifier combinations for shell objects
  • SHIFT+right click: Displays a shortcut menu containing alternative commands
  • SHIFT+double click: Runs the alternate default command (the second item on the menu)
  • ALT+double click: Displays properties
  • SHIFT+DELETE: Deletes an item immediately without placing it in the Recycle Bin
General keyboard-only commands
  • F1: Starts Windows Help
  • F10: Activates menu bar options
  • SHIFT+F10 Opens a shortcut menu for the selected item (this is the same as right-clicking an object
  • CTRL+ESC: Opens the Start menu (use the ARROW keys to select an item)
  • CTRL+ESC or ESC: Selects the Start button (press TAB to select the taskbar, or press SHIFT+F10 for a context menu)
  • CTRL+SHIFT+ESC: Opens Windows Task Manager
  • ALT+DOWN ARROW: Opens a drop-down list box
  • ALT+TAB: Switch to another running program (hold down the ALT key and then press the TAB key to view the task-switching window)
  • SHIFT: Press and hold down the SHIFT key while you insert a CD-ROM to bypass the automatic-run feature
  • ALT+SPACE: Displays the main window's System menu (from the System menu, you can restore, move, resize, minimize, maximize, or close the window)
  • ALT+- (ALT+hyphen): Displays the Multiple Document Interface (MDI) child window's System menu (from the MDI child window's System menu, you can restore, move, resize, minimize, maximize, or close the child window)
  • CTRL+TAB: Switch to the next child window of a Multiple Document Interface (MDI) program
  • ALT+underlined letter in menu: Opens the menu
  • ALT+F4: Closes the current window
  • CTRL+F4: Closes the current Multiple Document Interface (MDI) window
  • ALT+F6: Switch between multiple windows in the same program (for example, when the Notepad Find dialog box is displayed, ALT+F6 switches between the Find dialog box and the main Notepad window)
Shell objects and general folder/Windows Explorer shortcuts
For a selected object:
  • F2: Rename object
  • F3: Find all files
  • CTRL+X: Cut
  • CTRL+C: Copy
  • CTRL+V: Paste
  • SHIFT+DELETE: Delete selection immediately, without moving the item to the Recycle Bin
  • ALT+ENTER: Open the properties for the selected object
To copy a file
Press and hold down the CTRL key while you drag the file to another folder.
To create a shortcut
Press and hold down CTRL+SHIFT while you drag a file to the desktop or a folder.
General folder/shortcut control
  • F4: Selects the Go To A Different Folder box and moves down the entries in the box (if the toolbar is active in Windows Explorer)
  • F5: Refreshes the current window.
  • F6: Moves among panes in Windows Explorer
  • CTRL+G: Opens the Go To Folder tool (in Windows 95 Windows Explorer only)
  • CTRL+Z: Undo the last command
  • CTRL+A: Select all the items in the current window
  • BACKSPACE: Switch to the parent folder
  • SHIFT+click+Close button: For folders, close the current folder plus all parent folders
Windows Explorer tree control
  • Numeric Keypad *: Expands everything under the current selection
  • Numeric Keypad +: Expands the current selection
  • Numeric Keypad -: Collapses the current selection.
  • RIGHT ARROW: Expands the current selection if it is not expanded, otherwise goes to the first child
  • LEFT ARROW: Collapses the current selection if it is expanded, otherwise goes to the parent
Properties control
  • CTRL+TAB/CTRL+SHIFT+TAB: Move through the property tabs
Accessibility shortcuts
  • Press SHIFT five times: Toggles StickyKeys on and off
  • Press down and hold the right SHIFT key for eight seconds: Toggles FilterKeys on and off
  • Press down and hold the NUM LOCK key for five seconds: Toggles ToggleKeys on and off
  • Left ALT+left SHIFT+NUM LOCK: Toggles MouseKeys on and off
  • Left ALT+left SHIFT+PRINT SCREEN: Toggles high contrast on and off
Microsoft Natural Keyboard keys
  • Windows Logo: Start menu
  • Windows Logo+R: Run dialog box
  • Windows Logo+M: Minimize all
  • SHIFT+Windows Logo+M: Undo minimize all
  • Windows Logo+F1: Help
  • Windows Logo+E: Windows Explorer
  • Windows Logo+F: Find files or folders
  • Windows Logo+D: Minimizes all open windows and displays the desktop
  • CTRL+Windows Logo+F: Find computer
  • CTRL+Windows Logo+TAB: Moves focus from Start, to the Quick Launch toolbar, to the system tray (use RIGHT ARROW or LEFT ARROW to move focus to items on the Quick Launch toolbar and the system tray)
  • Windows Logo+TAB: Cycle through taskbar buttons
  • Windows Logo+Break: System Properties dialog box
  • Application key: Displays a shortcut menu for the selected item
Microsoft Natural Keyboard with IntelliType software installed
  • Windows Logo+L: Log off Windows
  • Windows Logo+P: Starts Print Manager
  • Windows Logo+C: Opens Control Panel
  • Windows Logo+V: Starts Clipboard
  • Windows Logo+K: Opens Keyboard Properties dialog box
  • Windows Logo+I: Opens Mouse Properties dialog box
  • Windows Logo+A: Starts Accessibility Options (if installed)
  • Windows Logo+SPACEBAR: Displays the list of Microsoft IntelliType shortcut keys
  • Windows Logo+S: Toggles CAPS LOCK on and off
Dialog box keyboard commands
  • TAB: Move to the next control in the dialog box
  • SHIFT+TAB: Move to the previous control in the dialog box
  • SPACEBAR: If the current control is a button, this clicks the button. If the current control is a check box, this toggles the check box. If the current control is an option, this selects the option.
  • ENTER: Equivalent to clicking the selected button (the button with the outline)
  • ESC: Equivalent to clicking the Cancel button
  • ALT+underlined letter in dialog box item: Move to the corresponding item
reference: http://support.microsoft.com/kb/126449
tip
Cannot access internet!!!!!
Using Windows Operating Systems:
Windows XP:
1.Powercycle equipment (Unplug power wait 15 seconds then plug back in)
2.Go to Start/Run/Type ncpa.cpl then hit ok.
3.Double Click Wireless Connection (Router Connection) Hit Properties.
4.Click on tcp/ip then hit Properties
5.Ensure Obtain ipaddress automatically is checked as well as Obtain a DNS server automatically is checked.
6.Restart Computer, If still unable to access internet check you Firewall:
Start/Control Panel/Windows Firewall/Change Windows Firewall Settings/Turn Off not recommended.
7.Last Go to Start/Run/CMD/Hit ok
A.Type netsh int ip reset reset.log Press Enter after every Command
B.Type netsh int ip delete arpcache
C.Type netsh winsock reset
D.Type ipconfig /flushdns
8.Restart Computer
9.If still having issues check for viruses or malware in your computer.
10..Refer to your manufacture.
Windows Vista/7:
2.Go to Start/Search Bar/Type ncpa.cpl then hit Enter.
3.Right Click on your connection usually (Wireless) then click Properties.
4.Uncheck Internet Protocol Version 6 IPV6
5.Click on Internet Protocol Version 4 IPV4 Then hit Properties (Do not uncheck IPV4)
6.Ensure Obtain ipaddress automatically is checked as well as Obtain a DNS server automatically is checked.
7.Restart Computer, If still unable to access internet check you Firewall:
A.Start/Control Panel/Security/Allow Program Through Windows Firewall/General Tab/Turn Off.
8.7.Last Go to Start/All Programs/Accessories/Right Click on Command Prompt then hit Run as administrator and hit continue.
10.Refer to your manufacture.
on Jan 11, 2011 • Computers & Internet
Why does my delete key act like a spacebar?
There are a couple options:
1. Your keyboard is broken, you need to replace it.
2. Try unplugging / replugging it un and or restarting your computer, that may fix the issue.
3. Your keyboard layout might have changed. If you are using a Windows computer, you can press CTRL + SHIFT to switch between layouts. Or you can go to Control Panel -> Clock, Language, and Region -> Change Keyboards or other input methods. From here, you can change your keyboard layout back to use.
Jeep liberty transmission not shifting
Brake saftey switch, what is happening is every time your restarting, your aslo probably hitting the brakes. Brake switch is sticking.
My keyboard is locked in windows 8
The keyboard may still work for starting safe mode. Use the right shift while pressing F8 on startup. See if you can change some of the keyboard settings and restart. Then see what it does. You might have to check device manager if no change. It's a start.
When I type on my keyboard on my computer numbers are popping up instead of letters
Press the Start key + R.
type osk in that box and hit enter
On this keyboard, try toggling numlock scrolllock and capslock a few times.
Also, try this too: Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
hope this helps
Try this. Press the Start key + R. type osk in that box and hit enter On this keyboard, try toggling numlock scrolllock and capslock a few times
or
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Router will not connect
Depending on what router or connection you are using try these steps.
Windows XP
1.Powercycle all equipment (Unplug)
2.Wait 15 seconds and plug back in.
3.Go to Start/Run/Type ncpa.cpl
4.Double click the connection you want to connect to
5.Click on tab next to General
6.Ensure that it is assigned by DHCP
7.Ensure It has a valid ip address It should start with 192.
8.Go to Command Prompt Start/Run/Type CMD and hit ok
9.Next to C: Type netsh int ip reset reset.log
netsh winsock reset
ipconfig /flushdns
10. Restart Computer
WINDOWS VISTA/WIN 7:
1.Start/Search Bar/Type ncpa.cpl
2.Right click on the Connection you want to connect to
and hit Properties
3.Uncheck Internet Protocol Version 6
4.Click on Internet Protocol Version 4 and hit Properties.
5.Ensure Obtain an IP address automatically is checked
Ensure Obtain a Dns Server automatically is checked as well
6.Exit out of everything
7.Go to Start/All programs/Accessories/Right click on Command Prompt and hit Run as Administrator then click continue.
8. Type: netsh int ip reset reset.log
Type: netsh int ip delete arpcache
Type: netsh winsock reset
Type: ipconfig /flushdns
9. Restart your computer.
10. If you are still unable to access the internet you may have a virus I would suggest running an Antivirus. I hope this Helped Good Luck
1helpful
How to lock a keyboard
  1. Press the Windows logo key + U. This will open the ease of access center. Click on the keyboard icon. It will say, "make the keyboard easier to use" next to it. In some versions of Windows you will need to get to the option by pressing the left shift key five times rapidly.
  2. Select "turn on sticky keys" and "turn on filter keys." Select "save." Your computer will now only make sounds when the keyboard is hit.
  3. Follow steps 1 and 2 to unlock your keyboard. Unselect the "sticky keys" and "filter keys" and click on "save."
  4. Lock your workstation. Press Ctrl + Alt + Del. A blue screen or a box will pop up that has a variety of options, such as restart or shut down the computer. Click on "lock this computer."
  5. Lock your workstation using the keyboard. Press the Windows key and the L key at the same time. This will lock the computer. To unlock press the combination again.
4answers
How to rebot acer 4220 laptop
usually holding down the power button for a long time will force a reboot. I am not sure if that is what your asking
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
