Ken Conway Posted on Jan 16, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dcr15 dewalt radio flashed red when plugged into wall single flash help please
Attique-ur-Rehman
Level 3:
Top Expert:
  • Dewalt Master 2,677 Answers
  • Posted on Apr 19, 2020
Attique-ur-Rehman
Dewalt Master
Level 3:
Top Expert:
Answers
2677
Questions
Helped
878122
Points
8006
Occasionally, the charger might show blinking red right to indicate bad batteries. ... This indicates that the battery already have a full charge. If charging is needed, briefly drain the batteries before trying again. If the light blinks red in about 90 seconds after battery insertion, then the battery voltage is too low.
5 Related Answers
Anonymous
  • Posted on Jan 06, 2009
SOURCE: RED FLASHING WALLS
so i instal
Anonymous
  • 3 Answers
  • Posted on Mar 06, 2009
SOURCE: flashing red light
Your power supply is faulty I'm afraid. Unless you have soldering skills, I am afraid you will need to contact a professional TV repair person. If you feel confident to try the repair, contact me with the model number, and I will let you know what components you need to change
Anonymous
  • 51 Answers
  • Posted on Aug 08, 2009
SOURCE: Dewalt dc011 won't charge or play on battery
could be a fuse in the radio. check with your local dewalt dealer.
Anonymous
  • 8197 Answers
  • Posted on Mar 31, 2010
SOURCE: i have a dewalt dc011 radio, it will not charge a
Sorry to say the unit has a short in it, You need to have it serviced to fix the problem.
Testimonial: "thanks, just had it looked at it's the charging unit thats gone £80 to fix :-( "
Repair Ahjoshe
  • 885 Answers
  • Posted on Jan 30, 2012
SOURCE: broken dewalt battery 18v lithium ion
When a Dewalt charger is showing a fast blinking red light it means the battery is no longer chargeable. It may be because of a bad cell or short inside the battery. Whatever the reason the charger will not charge the battery and it needs to be replaced.
7helpful
2answers
I have a DCB 101 dewalt 20V charger new and there is a red light flashing first time using it. Wondering if it.s normal and also I am looking for a free download of the owner Manual for a DCK294L3 kit...
The Dewalt charger's red light will flash while charging and go to steady red when the battery is fully charged. If you go to the Dewalt ServiceNET site at http://servicenet.dewalt.com/ you can search for the manual for any of your tools. DCK294L3 does not have a manual as that is the model number for the whole kit. Search for the model number of each of your tools and you can get the manual for them. Inside the manuals it also describes the different meanings of how the red light is flashing on your charger.
Feb 18, 2012 • Drills
Dewalt radio 011 wont power up with ac or dc but the red indicator light will flash one time when pluged in either ac or dc but definitly got pluged into 240
Sound like one of the Capacitors on the Power Supply has blown.
If it's the same on both AC & DC then its probably on the output of the transformer.
If you can open it up and post pictures or see if one has a buldge in the top or liquid leaking out.
My Dewalt DC011 has now got another fault. Recently had the internal transformer changed under warranty. But now have noticed after using it for a couple of weeks olugged it in and it started making a...
The original problem that damaged the internal transformer was not resolved. The transformer may be damaged again - it is used in the AC circuit but not in the battery. They are two different circuits. The red led is part of the AC. I would contact Dewalt and send it back explaining what happened. The part they replaced should be under warranty.
Have purchased a dewalt radio/charger through sears, was a close out where had no instruction for presetting channels 1-2-3-4 Not able to set, need instructions.
1. Select the Radio Station you want to save.
2. Press and hold the Memory button that you want that station on, 1, 2, 3, 4.
The display will flash the station number, when it stops flashing, the channel is set.
3helpful
Did not recieved operators manual with dewalt dc011 construction radio. need to know how to set the select channels. 1-2-3-4
No power to the radio but charger works
could be few issues, as of cracked boards, if you dropped it few times, or short in output/ internal power distribution. must be open by tech and troubleshoot properly. Definitely, not a do it yourself job.
Sorry.
2helpful
2 red lights flashing??????????
when two red lights flash, come to a complete stop at the intersection..ok..now for a solution.
unplug printer from wall and computer..
wait 5 min.
plug into wall only
try the test page again..
check back here next..before plugging into computer, please..
check your computer's warranty here FREE
Top Dewalt Audio Players & Recorders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
