Health & Beauty Logo
Andrea Nichtburg Posted on Jan 16, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Voyager electric scooter scooter does not drive when gas pedal is pushed down. Power is on and scooter is on full charge
Jim Pattison
Level 3:
Master:
  • Master 1,004 Answers
  • Posted on Jan 22, 2020
Jim Pattison
Master
Level 3:
Master:
Answers
1004
Questions
0
Helped
279137
Points
1705
Does the motor turn when power is applied across the terminals? Something is stopping the power to the motor. If the motor works, that is the problem.
5 Related Answers
Anonymous
  • 128 Answers
  • Posted on Nov 30, 2008
SOURCE: motor bogs down at stoplight when pushin gas pedal
The fuel pump relay will cause a stalling or no start condition. You are likely having mass airflow sensor, fuel pump, or fuel pressure regulator issues.
Bret
RepairPal.com
Anonymous
  • 5 Answers
  • Posted on Jan 13, 2009
SOURCE: sticky gas pedal
it is a dirty throttle plate. $280 is an absolute ripoff for a cleaning, it is about 10-15 minutes of work. They are probably quoting replacing the throttle body which about a $150 part.
Got to Autozone and get "CRC Throttle Body Cleaner". Remove aire inlet hose at throttle body with a screwdriver. Spray a *small* bit onto throttle plate, use clean rag or qtips to remove gum/varnish. Spray pivots and also clean around perimeter of the plate. Take it to an independent mechanic if you are unsure of the procedure.
Anonymous
  • 20 Answers
  • Posted on May 10, 2009
SOURCE: Van Sputters And Loses All Power When I Accelerate
Internal combustion engines requires 3 things... fuel, air, and spark. You do not have enough of one or more of these. If the wires and plugs are old, change them.  Air filter, same thing.  Fuel filter can also clog up with stuff after awhile. When you take a look at the air filter check where the air comes from.  It is possible a little critter has built a home and blocked the air flow (rare, but, it has happened).
oregoon
  • 175 Answers
  • Posted on Jul 12, 2009
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Anonymous
  • 166 Answers
  • Posted on Mar 07, 2010
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
The SFScout4 sat idle after operating fine. The battery gauge shows a full charge, but now the scooter does not run. I hear no sounds when go lever is pulled. Any idea why the unit won't operate?
Hi check if freewheel lever is in drive if scooter moves when u push it it's in freewheel push lever into drive
also check overload switch push the white button on the cowl c photo.
if you're computer has timed out this will shut down power remove key for a few minutes.
cheers
I lost a indicator light on my mobility scooter and now the battery runs out quickly
Are you losing battery fast with your electric scooter? What a pity! It should have been hard for you to run out of juice in a middle of a commute or lose steam just when you are about to have fun. Such is the downside of electric scooters, electric cars, electric motorcycles, and electric mobility devices that are powered by rechargeable battery. They seem to have the power of a flashlight, but as rechargeable devices, they should have more power than a flashlight. How could you be losing battery fast? You now at least relate to other motorists whose vehicles give away in the middle of the road, and without a refilling station or repair shop in sight.
Why you're losing battery fast
Why is your electric scooter losing battery fast? Something might be wrong with the battery pack or that something in your unit is rapidly depleting your power source. Maybe your charger is defective or not powerful enough to charge your e-scooter. Or the way you operate your unit over certain terrains could be the reason why your unit is losing battery fast. You cannot just say your retailer have sold you an e-scooter with a defective battery.
Done charging but your electric scooter does not start? What if it has no power at all? Think your e-scooter has been properly charged? There might be a broken or loose connection or two in your unit.
Limited power for short distances only? The battery could be faulty or has incomplete charge cycles. Or you either have a defective charger or an old battery. As a battery ages, its capacity decreases, as you should know. If you have the same battery for years, there is no wonder why your e-scooter is losing battery fast.
Charging done for the full required time (usually 6 to 8 hours), yet the electric scooter is still not indicating a full charge? You may have a faulty charger or a bad battery. You should also be wary about a battery that charges faster. If it takes long for an electric car to fully charge, how much more an e-scooter? Anything could be behind your unit losing battery fast.
Battery information
When you buy an electric scooter, be it be a two-wheeler or three-wheeler, always check the specs of the battery pack. Pay attention to the battery voltage and amp hours (AH), not just the chemistry (lithium-ion, sealed lead acid, or lithium-polymer).
Batteries of e-scooters are typically configured in 24V, 36V and 48V. Higher voltages e-scooters are generally faster, but there are factors that could affect performance, notwithstanding battery power, such as rider weight, terrain, and the efficiency of the unit's motor and drive system. One or two of these factors could be behind your e-scooter losing battery fast.
AH is as important as voltage. AH is the measure of battery capacity, an indicator of an electric scooter's range.
One three-wheel electric scooter (on a 300W motor) goes 12 mph and travels a maximum distance of 15 miles per charge of a 36V 7AH battery. Another three-wheeler (on a 250W motor) attains a top speed of 12 mph and a maximum range of 28 miles per charge of a 48V 10AH battery. A two-wheel electric scooter (1000W motor) goes 24 mph and has a maximum range of 10 miles on a single charge of a 36V (three 12 V) 12AH battery. Another two-wheeler (350W motor) has a 36V 10AH battery that ramps up a maximum speed and range of 18mph and 15 miles, respectively, on a single charge. Different electric scooters, different battery specs, different performances. Results may vary.
Knowing your e-scooter's battery (and the other components) is knowing your e-scooter well. That way you will have an idea why your unit is losing battery fast-and how you can troubleshoot it.
How not to lose battery power quickly
As owner, you can do preventive maintenance to avoid losing battery fast and ensure optimal performance of your electric scooter.
  • If your e-scooter has no power after a required full charge, check for any broken or loose connection. Remove the top or deck to reveal the wiring. Inspect the battery pack, switch, brake lever, throttle, and controller. Unsure? Take your unit to the retailer or service shop for check-up.
  • Give your battery a full charge. This will help your electric scooter avoid losing battery fast. Most batteries of e-scooters take up to 8 hours for a full charge. However, do not overcharge for more than 12 hours as this could possibly damage the battery. Charge your unit according to the required duration as specified by the manufacturer.
  • You can prevent losing battery fast by simply replacing it. Replace battery if you begin to notice a gradual decline in charge life. Moreover, replace an old battery with a new one.
  • It is also possible that newly installed batteries could rapidly lose their storage capacity. Have a licensed technician perform a battery test to determine current capacity. Avoid losing battery fast with professional assistance.
  • Don't leave battery uncharged for a long time. Any battery that is left uncharged for over six months becomes defective. You won't be able to successfully recharge a battery that is left uncharged for months. Charge before storage, and when in storage, charge every 30 days.
  • How to know if your battery is getting charged? Check for the indicator light on the charger. If it does not illuminate, battery is not getting charged. Get yourself a new charger.
  • Test your charger's output Voltage with the use of a multimeter. The output voltage should be a few volts above the charger's rated voltage (24V, 36V, 48V). If output voltage is zero or below the rated voltage, charger is defective.
  • Faulty charger port could be another reason why your electric scooter is losing battery fast. Test your e-scooter's charger port by plugging the charger into the port. Look for an illuminated indicator light on the charger. If indicator light illuminates once the charger is plugged into the e-scooter, this means the wires and wiring connectors going to the charger port are in good condition. The charger port is working properly.
  • You can also perform a battery test while operating your e-scooter to see how it is losing battery fast and how long the battery lasts. Give your battery a full charge first, and then drive at full throttle on flat terrain. Most e-scooters will have a range around 30-50 minutes on flat terrain. Battery is already worn-out and in need of replacement if it lasts less than 30 minutes.
  • Another way to check if your e-scooter is losing battery fast is to test the battery voltage, same way you test your charger's voltage with the use of a multimeter. The battery should be above its rated voltage level even if it has been in storage, has been driven or fully discharged and sits for a few minutes. If not, battery may be worn-out or defective. This calls for replacement.
  • Do not attempt extreme stunts with your electric scooter or risk losing battery fast. Though many e-scooters are durable and built to support heavy weight, the metal frames, wheels, and other components are unable to withstand extreme riding activities.
  • Do not drive e-scooter over water or else your unit will start losing battery fast due to battery's contact with water. If you do ride through water, dry unit and battery completely before storage.
  • Do not drive over uneven or rugged terrains. Though some e-scooters are designed for off-road use, uneven or unpaved surfaces can still cause stress on the parts and components. Drive without care over challenging terrains and your electric scooter will start losing battery fast.
Scooter battery meter dips
After 10 to 12 hour charge, unplug the charger, make sure the freewheel lever is in drive mode, you will know if it is because you have a hard time trying to push the scooter. Turn it on and try to drive if the meter goes to above the middle on the meter, it should ok, but, if the needle goes to red right away time for new batteries. Will need more info to go any farther. or you could go to www.strege.com/BlueDoc it is an app to help trouble shoot scooter problems.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
2helpful
Scooter won't move
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller).
The scooter charges and shows full charge when started. Scooter will not drive uphill - certainly seems to lack torque - when driving up hill battery indicator drops to red
Either the hill is too steep of a grade/incline, the weight of the rider is more than the scooter is designed to carry, or the battery does not have enough power. If the batteries are old or have not been maintained properly, they may not be getting a deep solid charge that is needed to operate on hilly terrain. This is indicated when the batteries show a full charge, and then drop off quickly after a short period of use. Make sure that you are not exceeding the recommended weight limit for the scooter and that your batteries are less than 2 years old. Inclines of more than 5-6 degrees are typically not recommended for safe operation.
I hope this information is helpful to you, good luck!
1helpful
Hi, I have obtained a scooter that is 4yrs old but unused and am having problems getting it to go. It is a Prestige Explorer 6 and I have charged the batteries which seem to hold a charge and show full on...
Hello, it sounds like you may have a few issues going with this scooter. Due to the age of the scooter, my first guess is the batteries. It sounds like there is enough power for the auxilliary systmes but not enough to power the scooter. Sometimes when a scooter sits for a while the gel inside the batteries will oxidize and prevent then from taking a full charge. The charger registers a full charge, but instead of being full of power, the batteries are full of crud and need to be replaced. Take the batteies to Auto Zone or somplace that can test them for free with a volt meter to ensure they are at the manufacturer's guidelines; probably 12 v, 33 amp.
If the batteries are good, the freewheel is in drive and the scooter still won't move, it may be a wiring problem or the motors may have siezed up. Check the wiring connecting from the accelerator/wigwag/controller to the motor to make sure they are talking to each other. If that is OK, the motors may have rusted or siezed up on the inside from sitting so long, which may be the reason why the scooter can't be pushed- the axle is locked up.
I hope this information is helpful to you- good luck!
Rover three wheel mobility scooter full charge horn working but just wont move
First of all,
Make sure the freewheel lever is unengaged (up or down ?) , this can be tested by pushing the scooter forward , you should hear gearbox clunk,(Freewheel not engaged) Not all scooters sound a alarm when freewheel is engaged.
is the power indicator working okay,
Does the Wig Wam move freely, the thumb throttle part,
Check under the seat to make sure you have not blown or tripped the fuse, if it's a switch simply pressing the button will sort it, if not check the two prong fuse ,
you may also have some reset buttons on the stem so look out for them.
Now let me what you tried
Regards
GeWiz.
Odyssey 4-wheel electric scooter - The following has happened twice in a 6 month period near the same geographic neighborhood location. While driving the scooter, which is fully charged and operating...
Always check the battery connections first because too many times it is a loose connection or battery bolt. it would happen more if you drive it a long distance, or up a hill and the controller over heats or if you are hitting a bump. when the controller cools down it drives again.
2helpful
4answers
Electric scooter Troubleshooting
A small tip here - bigger is better. The large diameter wheels clear gaps in concrete or pavement that would hang up a skate wheel or a scooter with smaller wheels. Most electric scooters also handle well in gravel and small terrain features. We don't recommend slamming electric scooters into a curb to get over it like some people do with their bike. This could result in damage to the electric scooter. Simply Ollie up a curb and keep going.
Top Electric Health & Beauty Experts
Rob Hill
Rob Hill
SmartAviator
SmartAviator
jws1013
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
