Question about Brother Office Equipment & Supplies
I just received my THIRD in a row Brother ScannCut sdx125. Right out of the box new, when turned on the screen shows the error: Lever Feeder Released when it is not released; it's locked.
5 Suggested Answers
Anonymous
SOURCE: MP830 canon 3in1 scanner lock.
my mp830 will print, copy, fax but it will not scan to the computer. Please help
Posted on Sep 19, 2008
Anonymous
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
Anonymous
  • 3 Answers
SOURCE: on my cu cadet zero turn only the left side turns
Check the hydraulic oil level for the hydrostat drives(if it has a reserve tank located under the seat. Some ZT's don't have the reserve tank. Don't over fill that tank. 1/4 inch above the bottom is all it needs.)
Also, check the steering arm bolts. Very often they work themselves loose and the arm doesn't pull the valve rod that controls the hydrostat unit.
Posted on Oct 30, 2009
Anonymous
  • 86 Answers
SOURCE: STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Posted on Apr 18, 2010
Testimonial: "Haven't tried the suggested solution but makes sense."
upbeatjunk
Tim Levesque
  • 231 Answers
SOURCE: Canon LiDE 110 gets error code "release the lock
Unfortunately if the scanner is unlocked and you have reinstalled the software with no luck, then the scanner is defective.
If your scanner is still under warranty you can get a free repair or replacement form Canon...your best bet would be to contact them via one of the methods listed here:
http://usa.canon.com/cusa/consumer/standard_display/contact_us_consumer
The LIDE scanners are nice, I understand your frustration.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Posted on Jul 24, 2011
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
My power third row seat don't work, I tested the motors and they work fine when power directly. When I measure the voltage at the connectors I get about +/- 10 volts, from any of the 4 switches. I verified...
Your missing something's G-404 has nothing to do with it !
Seats - Third Row
The third row seat:
  • is three-passenger seat.
  • a 60/40 bench seat.
  • folds down for more cargo area.
  • has optional power fold down seats.
Third Row Power-Fold Seat
CAUTION: To prevent possible damage to the third row seat or the safety belts, make sure that the safety belts are not fastened when moving the seat to the load floor position.
CAUTION: Make sure that no objects such as books, purses or briefcases are on the floor in front of the third row seats or on the seat cushion before lowering the backrest(s).
The third row power-fold seat consists of the following electrical components:
  • right third row seat relay.
  • left third row seat relay.
  • right power-fold seat motor.
  • left power-fold seat motor.
  • right front third row seat switch (if equipped).
  • left front third row seat switch (if equipped).
  • right rear third row seat switch.
  • left rear third row seat switch.
For the third row power-fold seat to operate, a shared ground is supplied by the body security module (BSM) to both of the power-fold seat relays, enabling the seats to then be moved by pressing one of the third row power-fold seat switches. The third row power-fold seat operates only when the vehicle is in PARK and the liftgate glass, liftgate door or any entry door must be open.
The third row power-fold seat motors transfer movement to a drive gear assembly to raise and lower the seat backrest. The power-fold seat motors rotate a short drive cable which is connected to the drive gear assembly.
The relay's are located in Aux. relay box #2
May 24, 2017 | 2003 Ford Expedition
Cant remove third row bucket seats sequia
To recline the third row seats in the Ford Flex you should be able to press the control on the side of the seat.
------------------------obd2express.co.uk
http://www.obd2express.co.uk/wholesale/vcm-metal-box-ids-jlr-new-vcm-release.html
Nov 26, 2012 | 2002 Toyota Sequoia
2004 ford expedition: changed battery, now rear seats will not go up or down. One is up the other one is down. They were working fine before the battery was replaced. Wifes car need to fix, she is...
Call the dealership and ask them how to reset the electronic on your Ford Expedition after changing the battery. Anything else is happen? Maybe like the radio wont turn on, hit the turn signals and the windshield wiper turn on. ***** things happen after replace the battery. I know what it is, it the darn wigits. GB you....stewbison
Aug 21, 2011 | Ford Expedition Cars & Trucks
An error is displayed that clear scanner jam.
Check the Paper Sensor on the ADF. If it is stuck, a Document Jam Error will occur because the scanner will attempt to feed documents when there are none. The sensor I'm speaking of is a black plastic lever that sits in a slot to the right of the feed roller. It should stick up through the slot (3/4 inch) and spring back if depressed and released.
Nov 24, 2010 | Brother MFC-8460N All-In-One Printer
No matter what i do the paper keeps getting jammed before it comes out... It looks like it's getting hang up on something by the front rollers... This is really making me very mad this morning....
I understand your frustration. Try this solution.
* Push down the purple paper lever located on the right side of the multi-purpose sheet feeder and pull the jammed paper upward and out of the feeder.
* Open the scanner cover by pulling the lever located below the control panel, toward you and lifting the cover. Make sure the cover is completely open. Check to see if any paper is left in the paper path.
Close the scanner cover.
Remove the paper in the multi-purpose sheet feeder. Adjust the guides in the sheet feeder to the position for the paper size you are using. Fan the paper well, push down the paper lever. Load the paper with the lever down. Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper (20lb paper) or up to 10 envelopes.
* Turn the power back on.
I hope this helps you.
Aug 03, 2010 | Brother DCP 1000 All-In-One Laser Printer
Brother MFC 8660DN "Toner Error Reinstall Drum I got a new drum, new toner and still printer isn't working and show the error reinstall drum unit please help
Pull the drum/toner out and look into the machine, at the wall on your left. There's a little plastic lever there that pivots to detect a new toner cartridge. Sometimes the lever gets sticky; wiggle it to free it up. If you feel brave enough to remove the outside cover of the machine on that side, you can put a dab of grease on the lever's pivot.
Apr 04, 2010 | Brother MFC-8860DN Printer
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
Close the back cover message
Bradley Mhishi
remove the paper tray under the printer and then remove the metal plate they is a rod that guides the paper ensure that the spring for that rod is in place and allign that rode that should get you going. Easy hey .i checked the back of my printer and it took me a day to figure it out, it was only when i took it apart and check every component when i realized the importance or this piece of plastic rod on a spring..
Sep 12, 2007 | Brother IntelliFax-2820 Laser Fax
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
