Question about Building Materials
Have a apollo 634 gate opener. gate opens ok. when closing, it will not turn off at the stop point. it reopens.will not adjust in the extend adjustment screw.
Anonymous
SOURCE:
Anonymous
  • 246 Answers
SOURCE: Is the carb adjustment screw on bottom
Hello
>>The Following is an Instruction File I made for Correcting this Problem. Any Input is Appreciated.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers.
>>There are Several Location for the Air Mixture Screws.
>>The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is the Nearest to the Engine.
>>The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>The Engine Idle Screw is Usually Easy to Identify because you can See where it Makes Contact with the Carburetor Throttle Shaft Plate Stop Ear. The H and L Air Mixture Screws Go Into the Body of the Carburetor and the Tips Cannot be Seen.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore).
>>If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required.
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns.****
>>Holding the Throttle Full Open, Start the Engine.
>>Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle.
>>Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle.
>>Reset the Engine Idle if Required. If This Carburetor has a Single Air Adjustment.
>>Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Rapidly Throttling from Idle to Full Throttle.**
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
Anonymous
  • 10 Answers
SOURCE: crib model 017201. I need the tan plastic part that screws into the top of the adjustable gate and slides thru the side rail. Jeff
You can email them - they emailed me the instructions and parts list in a 16 page pdf.
customerservice@sjfdec.com
Here are the instructions for your crib. Please review them and see which parts you will need. We accept Visa or Master Card. Parts are non returnable. Delivery is normally 7-10 business days. We do have replacement parts for this crib. Please review the instructions and see what you will need. J Thank you, Cindy Customer Service Rep Simmons Juvenile Furniture ':Phone: 1-800-218-2741 ':Phone: 1-920-779-4004 7:Fax: 1-920-779-4216
Posted on Jun 01, 2009
geoff hunter
  • 4793 Answers
SOURCE: 2001 VW Jetta Headlight adjustment. Headlights
sometimes the headlights stick to the adjusters,just pull/push(wiggle it)to free it, then try setting beams.
Posted on Apr 14, 2010
swolfinor
STEVE WOLFINBARGER
  • 504 Answers
SOURCE: Stanley garage door opener chain screw adjustment
THE ADJUSTMENT IS SUPPOSED TO HAVE A 2ND NUT THE TWO TIGHTEN AGAINST EACH OTHER AND ACT LIKE A LOCK
Posted on May 26, 2010
swolfinor
STEVE WOLFINBARGER
  • 504 Answers
SOURCE: Garage door closes and then automatically opens half way
ADJUST THE DOWN LIMIT IT THINKS THERE IS AN OBSTRUCTION AND IS REVERSING LIKE IT SHOULD.
TURN THE LIMIT ABOUT 1/4 TURN AT A TIME.
HOPE THIS HELPS
Posted on Jun 05, 2010
How to adjust open close limits on a 4 meter gate for a Germin motor
on the shaft that controls the arm or gear for the gate movement there will be 2 cams
open the gate and then loosen of one cam and adjust it off the micro switch until the gate is fully open
lightly tension the screw and then close the gate
repeat the adjusting on the second cam until the gate is fully closed
tension up the screw and then using the remote open the gate when it is fully open leave it or in it is not make small adjustment to get it open
press the remote to close the gate and again adjust to properly close the gate
May 02, 2018 | Cars & Trucks
Have a BFT Phobos BT gate opener. The problem I am having is my gate won't close all the way. There is a small gap. I tried to set the limit switch by removing the screw but it isn't...
The opener may have been mounted improperly or may have slipped from it's original mounting location. You may not be able to make an adjustment because the arm is already fully extended.
You may have to re-position the gate opener.
Fixya doesn't do repairs. Posting a question here is like calling the public library for an answer that they can look up.
Feb 02, 2015 | BFT R93524500001 - Swing Gate Kit, Single,...
Gemini gate motor
Check if it has stops anywhere in the system, usually there are micro switches that are activated by arms, etc that tell it how far to open and close. You may need to adjust them.
Aug 20, 2014 | Cars & Trucks
2007 yukon xl lift gate unable to open
try open the left back door first then the outher one
Jan 03, 2014 | 2004 Chevrolet Suburban
My gate starts to open but then stops
Need more information.
Firstly, engage the manual release inside your motor and then operate gate by hand. Pay attention to any spots that are hard to push, this would indicate some sort of mechanical obstruction causing the motor to stop. Try remove obstruction.
Secondly, measure the voltage on your battery while trying to operate the gate. If your battery drops below 11.5V the control board will shut down. If so, replace battery.
Feb 04, 2012 | Apollo 7000etl Slide Gate Opener Plus 2...
Two identical Sears doors jump about 6 to 8 inches up when opener button pressed. Periodically doors will stop at that point, need to be closed and then reopened to operate properly. Have tried adjusting...
It sounds like the door springs may be mis-adjusted. Release the doors from the opener and try raising and lowering them manually. They should not try to rise on their own.
Jul 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wiring diagram
ok, try purchasing a Chilton Manual (NOT a Haynes- it's junk). In it you'll find the complete wiring diagram.
Aug 03, 2008 | 1998 Ford Escort
Building Materials Logo
41 people viewed this question
Top Building Materials Experts
Tom Chichester
Lawrence Oravetz
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
