Question about Lands Phones
Voicemail on CL2909. New work phone and need to change from old user to me.
5 Suggested Answers
Anonymous
SOURCE:
askers63292
SOURCE: answering machine not working
change how many rings your voicemail picks up in or cancel it.
set your answering machine to less rings than your voicemail.
Posted on Nov 08, 2007
cnavarro
Carl Navarro
  • 2460 Answers
SOURCE: Need to set up user voicemail box (new employee)
Go back to your vendor and get the password for mailbox 999 and the instructions to log into it.
The mailbox exists or it wouldn't ask for a password (they're assigned by default), so you need to go to mailbox 999 and chose option 6 1 3 which is mailbox administration reset password. That will clear the password and you can log into the voice mail automatically from the extension by dialing the voice mail access code.
Post back if you have any problems.
Carl
Posted on Sep 18, 2008
brekke26
SOURCE: FSK Voicemail Indicator not working
When you press the voicemail button on your phone it is retrieving messages stored internally in your phone. Verizons Voicemail is a seperate entity where the message reside on the server. If you do not want to use the Verizon Voicemail, simply call the business office and ask them to remove voicemail completely from the account. That way your phones internal answerming machine whille then catch all the voicemails and you can go back to using your voicemail button to listen to them. Hope that helps you and everyone else out.
Tony T.
Posted on May 22, 2011
bobmarley54
bob marley
SOURCE: Phones acting as if voicemail box is full eventhough there are no voicemails at all.
call the phone company
Posted on Nov 19, 2013
Testimonial: "The voicemail system is utilized through our in office phone system, not the phone company."
Hi, How to change Cisco IP Phone voicemail password on router. Thank you
on the CLI you need to change the username and password on the ephone for that phone. Then you need to session into the CUE module and change the password there as well. do a show run and find the username and password that you need to change and then do config t and change the password. The user can also do this on the phone if they know the previous password.
Aug 31, 2017 | Cisco Computers & Internet
How do I increase number of rings on CL2909 ATT phone
The CL2909 does not have an answering system. Thus the number of rings will depend on the caller's patience or your voice mail service. You need to check with your telephone provider to find the procedure to change the number of rings before your voice mail system answers the call. You'll have to get into the voice mail system and then access those options.
AT&T has the manual for the CL2909 on the product page: https://telephones.att.com/pd/290/CL2909-Speakerphone-with-caller-ID-call-waiting . The direct link to the manual is currently https://cdn-media-att.vtp-media.com/products/CL/CL2909/CL2909_CIB_i14.0_20170210.pdf .
I hope this helps. If you add a comment with your telephone provider, I may be able to find a guide to their voice mail system settings.
Jul 26, 2017 | Lands Phones
I need att manual for cl2909
http://cdn-media-att.vtp-media.com/media/p/document2/products/%7B5A9D7833-E5B1-4913-BB01-23BF5B1FE914%7D/CL2909_UM_11_Final.pdf
Aug 22, 2014 | AT&T ATT Speakerphone CL2909
How do I change voicemail setup?
Login to you voicemail and listen to the prompts
Jul 23, 2013 | Mitel 5330e IP Phone 50006476
I can't figure out how to set up a voicemail or answering machine
The phone doesn't have an answering system built-in. If you use a voicemail service, you will need to check with the provider for the phone number and then follow their directions to set up your mailbox. If you are connecting a stand-alone answering machine, you will need to daisy chain the devices. Connect the phone cord from the wall jack to the answering machine IN port. Then use another phone cord from the answering machine OUT to the CL2909 TEL port. (If you are using a fax modem (or regular modem), with an anwering machine feature on your computer, then you still want to use this chain method. The data port may not let the computer answer a voice call.)
If you are using a free standing answering machine, after connecting everything together, make sure that you hear a dial tone and can properly make calls. If you do not get a dial tone, replace cables. (I recommend you check that the phone works by plugging it directly to the wall jack before doing a daisy chain of devices.) Turn on the answering machine and set the outgoing message and number of rings as per the directions for the answering machine.
If you have any problems, make sure that the line is good. I use an old rotary phone to check my service connection (at the box since that has RJ-11 connections in my home). You may want your phone company to check if the line is good to your home if the service doesn't have RJ-11 connections. If the problem is in the wiring, check the jacks (loose wire/broken wire) and exposed wiring (missing insulation/breaks). You may need a professional to check in the walls; your telephone service provider will fix this for a fee. If the problem is outside, then the provider will fix it free.
You can get the manual and guick start guide as PDF files from AT&T: http://telephones.att.com/att/index.cfm/product-detail/?ProductID=290 . The links are on the right hand side of the page.
I hope this helps.
Feb 07, 2011 | AT&T CL2909 1-Line Corded Phone
Changing user on voicemail
ill need to log into Manager and under that users tab, you can reset the password or delete the mailbox.
Jun 22, 2010 | Avaya 5400 Series 5410 Phone
The voicemail light is fully lit(NOT FLASHING)it's not going away
First off we need to know what color it is.
Green-Dial "0" from the problem phone and that should clear it.
Red-Dial "Feature 99 Feature". If that does not work.
Leave a message in that users mailbox. From that users phone check and delete that message.
If neither of these operations work then you may have a bad port which means you may need a new station card. The part is an ESI(8)-U10-ETU, ESIB(8)-U10-ETU or an ESIE(8)-U10-ETU. The U10 might be different.
Let me know how these options work.
Nov 17, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Answering machine not working
Aug 29, 2007 | GE Telephone pr521w
Lands Phones Logo
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
