Question about Watches
How do you set time on solar lithium 3 bar water resistant tghk watch
5 Suggested Answers
Anonymous
SOURCE:
David Tolond
  • 2501 Answers
SOURCE: I need instructions how to set time on Tozai wrist
You can get a set of instructions from their web site (tissot.com).
At the bottom of the page there is a menu; select "warranty" and a number of alternative PDF files appear on the left.
If you can't see what you want, select "user manual" from the menu at the top and enter the details of your watch.
Choose the one that is suitable for your watch and download
Posted on Mar 03, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Set time on tghk watch
As there are no possible watch manuals for unknown brands, all I can say is:Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals.Go through all and you will find the right one, as all watches stand on globally accepted basics. It may take some time, but at the very end you will get what you want.Rate me, please
Posted on Mar 15, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: How do set alarm on my Seiko stainless steel water
Click on my name (escapement), then click on TIPS AND TRICKS. Browse through all and you will find the link to all SEIKO watch manuals. Rate me, please.
Posted on Jun 24, 2010
ra122022
SOURCE: Need to set time on WalMart TGHK watch.
Use the Mode button to get to the time display. The seconds should be flashing. Then press the Reset button once and the Hours should flash. Use the ST/SP button to increment through the hours. When the hour is correct, press the Reset button again the get to the flashing minutes display. Go through these steps until all items are set the way you want them.
The alarm is done similarly by pressing the Mode button until the AL displayes and if in small font the ALM and/or CHI display next to the AL, you can turn them off by pressing the reset button until both are off. If you do want the Alarm and time set then leave ALM set but set the time using the reset button to get the hours flashing or minutes flashing and use the ST/SP to increment to hour/min you want. Finish the sequence by pressing the Mode button once. If the ALM or CHI are set, then in the Time display you will see the ALM and/or CHI indication next the day of the week.
Posted on Nov 04, 2013
Mar 15, 2010 | Watches
I need instructions how to set time on Tozai wrist watch. It has a "Bluelite" and "Lithium" Alarm Chronograph water resistant and electro-luminescent.
Mar 03, 2010 | Tissot T-Touch T33759851
Is the battery on the G-Shock MT-G recharge either by motion or sun light?
As you will see from the extract from the web site, these watches are solar powered.
" Tough Solar Power
  • Shock Resistant
  • 200M Water Resistant
  • 29 times zones (48 cities), city code display, daylight saving on/off
  • 4 Daily Alarms and 1 snooze alarm
  • Countdown Timer
    Measuring unit: 1 second
    Countdown range: 1 second to 60 minutes
    Other: Auto Repeat
  • 1/100 second stopwatch
    Measuring capacity: 23:59’59.99”
    Measuring modes: Elapsed time, split time, 1st-2nd place times
  • Auto Calendar (pre-programmed until the year 2099)
    12/24 Hour Formats
  • Accuracy: +/-15 seconds per month (with no signal calibration)
  • Storage Battery: CTL1025
  • Battery Power Indicator
  • Power Saving Function
  • Approx. battery life: 6 months on full charge (without further exposure to light)
    Module 5055"
Feb 03, 2010 | Watches
I have an activa lithium water resistant watch #AD632=010. The light works but the digital clock doesn't.
If there is no time displayed the watch is just dead. You can try a new battery or just get a new watch.
If you can't seem to set the time: Press and hold Mode until it flashes a time and the letter A . This is how you set the alarm. Press mode again and you can set the time. start stop button moves between seconds, min., hrs, and days. reset changes the value.
Jan 28, 2010 | Activa Watches
If its digital that makes it more difficult to give setting directions online. Need to know the exact model #. I would do a google search to try and find your watch and you might find a manual online. OR you could seek out a local watch repair business and they should be able to set it with no problems. Most Sears have a watch repair kiosk in their stores! I woudlnt take it back to Walmart because they are just sales people! They have limited watch knowledge!
Jan 09, 2010 | Watches
Casio 2688 Wave Ceptor - No Display
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
Jerry G.
Feb 23, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
