Sewing Machines Logo
L
Luann Sliwicki Posted on Jan 15, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a singer 4562 t sewing machine. I am trying to use the attachment for zipper and it will not go down tight to feeder. The fabric is loose.
Attique-ur-Rehman
Level 3:
Top Expert:
  • Singer Master 2,677 Answers
  • Posted on Apr 21, 2020
Attique-ur-Rehman
Singer Master
Level 3:
Top Expert:
Answers
2677
Questions
Helped
879814
Points
8006
You can purchase attachments are available on the website
http://www.singerco.com/accessories/manuals.html
5 Related Answers
Anonymous
  • Posted on Nov 29, 2008
SOURCE: singer electronic control sewing machine model number 4562
You can download the instruction manual for free instantly.  Or pay $15 for a hard copy.  Some attachments are available for purchase on the website, others you can purchase at JoAnn Fabrics.  Good Luck.
bargainbox
Hassy
  • 1388 Answers
  • Posted on Sep 02, 2009
SOURCE: singer 237 stitches loose on bottom of fabric
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
bargainbox.com.au
Anonymous
  • 1116 Answers
  • Posted on Mar 13, 2010
SOURCE: thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
Anonymous
  • Posted on Aug 01, 2010
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Anonymous
  • 415 Answers
  • Posted on Mar 23, 2011
SOURCE: my top stich is tight,but bottom is loose of my
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Do you oil a singer 4562 and if so, how?
The Singer 4562 does not need oiling by the user.
Most Singer sewing machine manuals are available here: https://www.singer.com/support . The direct link to the manual for the 4562 is https://res.cloudinary.com/singer-sewing/image/upload/fl_attachment/Singer-Website-Library/outdated_product/SINGER_4562_4572_9032_93220_93234_9430_9444_and_30920_Sewing_Machines.pdf . The directions for cleaning the sewing machine are on pages 39 and 41. The only other regular user maintenance is changing the light bulb.
I hope this helps.
1helpful
How to attach zipper foot on singer inspiration
Here is a copy of your manual.
http://www.singerco.com/uploads/download/498_4205_4210.pdf
Most modern machines have snap off and snap on feet. Grasp the foot that is on there and push down. Then while lowering the foot, align the little bar on the zipper foot and watch it snap in. Easy.
1helpful
2answers
I hear a knocking sound on my machine when I sew, and sometimes the thread pulls and messes up the fabric... any ideas?
The bobbin case and shuttle need to be cleaned and the machine oiled.
When you thread the machine, always have the presser foot up.
When sewing and you need to reposition the fabric, make sure the needle is down into the fabric before raising the presser foot.
When the presser foot is up, the tension opens and does not control the flow of the thread and you get a messy stitch or a jam.
Refer to page 84 of the manual for your machine. If you do not have a manual, download one free at the Singer Co. website. It is important to
follow the instructions in the manual.
When I am sewing the needle moves up and down and so to the feeder feet but it will not pull the fabric through. I am not sure what to do...
Try lengthening your stitches on your stitch guide, it could be trying to stitch too tightly together & not stitching 'forward'....
2helpful
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
The threads are not tight on my serger
Here is an easy way to get your thread adjusted. Rethread the machine using four different colors. Then sew and for example the "yellow" thread is loose on the fabric, you know to adjust the tension with the yellow thread. Also a good starting place on your dials is 4-3-2-1 from left to right. Start with the tension set there and then adjust as needed.
12helpful
3answers
Singer electronic control sewing machine model number 4562
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
