Coffee Makers & Espresso Machines Logo
L
Lynda Morgan Posted on Jan 14, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My cuisinart coffee pot DCC-3000 12 cup coffee gauge is stuck on full how to get it to move. Cleaned pot with vinigar
john h
Level 3:
Top Expert:
  • Cuisinart Master 29,494 Answers
  • Posted on Apr 20, 2020
john h
Cuisinart Master
Level 3:
Top Expert:
Answers
29494
Questions
0
Helped
7551677
Points
193449
Need to clean whole unit just not pot
Testimonial: "I cleaned whole unit inside and out ran thru 3 times and worked on it for three days. It sounds like something is disconnected inside take a weight that moves the needle, but you can’t get to it."
5 Related Answers
Mike Manes
  • 19 Answers
  • Posted on Jan 19, 2008
SOURCE: Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Anonymous
  • 4 Answers
  • Posted on Nov 15, 2008
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
KBeaN1
  • 19 Answers
  • Posted on Dec 27, 2008
SOURCE: Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
ThaMp3Doctor
ThaMp3Doctor
  • 8597 Answers
  • Posted on Jan 09, 2009
SOURCE: Cuisinart DCC-1000 shuts off on it's own
Unplug it for 20 minutes or longer to fully reset it. At that point, the default shut-off time will be two hours, unlss you use the auto-off to increase this time limit to 3 or 4 hours.
-Tha Mp3 Doctor
Anonymous
  • 4 Answers
  • Posted on Mar 05, 2010
SOURCE: Cuisinart Dcc-1200 coffee maker is gurgling a lot,
I had this same problem and found that coffee grounds had somehow gotten in to the water reservoir and had been circulating thru the machine clogging the charcoal filter. This must have prevented the water from entering the heating chamber efficiently and therefore continued to gurgle until it all got thru. I flushed out the reservoir by holding the pot upside down and shooting water into the reservoir. It took some time to get all the grounds out. I took out the charcoal filter, flushed out that section and replaced it with a new filter. When finished, I ran thru a solution of white vinegar for good measure and bingo!! The coffee pot works perfectly.
Cuisinart brewer gauge stuck on full. Coffee on demand DCC-3000.
After repeated attempts to fix our Cuisinart coffeemaker gauge, I noticed a metal mechanism in a grooved area at the inside front of the coffeemaker. I was able to push it up and down, which caused the level indicator needle to go back and forth between empty and full. Determined that the hook at the front of the coffee reservoir matched up with this mechanism. There wasn't enough tension in the hook to depress the metal mechanism. Ordered part #DCC-3000CR for my coffemaker model through Cuisinart.com. Just installed the new coffee reservoir and the gauge now works!
2answers
Are there replacement pots for the DCC-KE12 coffee makers????
Replacement pots for the DCC-KE12 coffee makers is Cuisinart DCC-1200PRC 12 cup replacement pot.
2answers
Cuisinart DDC-2200 coffee maker problem: Sometimes the unit brews less cups than cups of water put into it. Then, after while, you get a brew that give 2 or 3 cups more than what was put into it. The...
Clean the pot by brewing a full pot of undiluted vinegar, then rinsing it by brewing 2 full pots of water through it. Also, change the charcoal filter on a regular basis. We clean the pot this way every month and replace the filter every 2 months.
2helpful
2answers
Coffee tastes like plastic!
We have had our DCC-1200 for 3 months. The plastic taste occurs about every 3rd pot, and it does NOT get better. We've wasted over a pound of coffee. Cuisinart says we are the only people in the world with the problem. Well, I guess not...
Clean button keeps blinking
Unplug the coffeemaker for one hour, and the self-clean light should come off.
-Tha Mp3 Doctor
Coffee maker doesn't brew full pot
you must have a filter and coffee in the basket for a full drain.the weight of the water is enough to open the basket when its full but as your trail run ended the final amount of water is not enough to open drain drop. with filter and coffee in it there is enough weight to keep drain drop open so all water can drain!
1helpful
Coffee doesn't brew full pot
It's possible that the hose or valve running from the tank to the heater is partly clogged. See superkev2000 and W5VSI fixes posted here.
5answers
Buy new coffee jug?
Replacemet pots for the DCC-KE12 coffee makers is Cuisinart DCC-1200PRC 12 cup replacement pot.
Top Cuisinart Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
john h
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
