SOURCE: 2004 Dodge Ram Diesel. Check engine light comes
You will need to have a diagnostic test on this vehicle which will then provide you some error codes.Then once you get the error code you can start looking where the fault is.Hope this helps.
SOURCE: engine code $7E8: engine
$7E8 and $7E9 are sub menus for the Engine and Transmission. You need to select one and press enter. It will then give you the code for that sub menu.
SOURCE: would like to know what is code number 7e8 and 7e9 on a jeep cherokee thank u
as I said before that's not an engine code. that is just the menu on your reader. you need to select the engine on the reader then select read codes. your not using the code reader properly
SOURCE: What do these codes mean 7E8, 7E9
The codes you listed are not valid Powertrain codes, which happens with some brands scan tools.
ALL P codes are 4 digit codes, preceded by the letter P - example would be P0430
you need to scroll thru your scan tool's menu to find the P codes and then post them here
SOURCE: We have 2013 Subaru Impreza getting codes 7E8 Engine and 7E9 A/T
Hi. I think you bought a new scan tool. No Problem. 7E8 and 7E9 are subcategories for the engine and transmission. Scroll down some more. OBD2 engine codes will always start with "P". Example: P0300- Random misfire. Good Luck.
