Paul E PARNELL Posted on Jan 14, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to hook up an older subwoofer to my newer Vizio TV how to single Jack on the subwoofer it is a rca subwhoofer
Level 3:
  • RCA Master 19,187 Answers
  • Posted on Apr 20, 2020
RCA Master
Level 3:
Answers
19187
Questions
0
Helped
4344693
Points
82261
You did not list the model numbers of either item but I can tell you that the new televisions use HDMI to send and receive audio. With that in mind, there is no way to do what you want to do unless you buy a converter like this one: https://www.amazon.com/AGPtek-SPDIF-Extractor-Converter-output/dp/B00ECTHIKK
5 Related Answers
Anonymous
  • 752 Answers
  • Posted on Sep 12, 2007
SOURCE: LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Anonymous
  • 46 Answers
  • Posted on Nov 08, 2007
SOURCE: RCA TV - Trying to hookup new dvd/vcr player to old tv with only antenna input
The input on your television is probably coaxial (for cable or an antenna) which means it needs an RF modulated signal. You can find one of those at your local department or electronics stores. Just look for an "RF Modulator" or "video-RF convertor." They're most commonly used to hook video games up to older televisions.
Now, if you've got an old VCR handy, that has an external input, it already has the RF modulator built-in.
Anonymous
  • 236 Answers
  • Posted on May 03, 2008
SOURCE: Yamaha RX-V1200 subwoofer connection to Mirage BPS-150i subwoofer
just connect your subwoofer mono RCA to your amp sub single out rca connector. you do not need to megre all those 4terminals into one. in fact internal circuit of those 4rca are merging inside to one since the sub uses only a single amp. 4inputs was meant for sources with multiple sub out
Anonymous
  • 93 Answers
  • Posted on Feb 21, 2009
SOURCE: JVC - Problem connecting a Powered Subwoofer to a Receiver
Have you set speaker setup configuration to SUBWOOFER YES? Also check SUBWOOFER OUT ON/OFF button on the front panel.
B52Tony
Tony Nguyen
  • 96 Answers
  • Posted on Jun 16, 2009
SOURCE: hooking up external speakers to a VIZIO
There is only one choice of audio out and that is the optical out put which locate on the far right if facing back of TV.
3answers
How do I hook up Vizio soundbar to Sanyo tv?
Use the left and right audio out from the TV
I have an rt2870 and am just wondering where i connect the yellow subwoofer cord to the TV at, and i set my tv setting for the surround sound
You shouldn't connect the subwoofer to the TV. Just connect the Right and Left audio cables (red and white RCA plugs) to the TV audio out and then the other side goes receiver's audio in. If you are using the subwoofer that came with the unit, connect it to the sub port (purple and grey or black striped). The red and black striped cable goes to the subwoofer control.
If you are using another active subwoofer, connect it to the RCA jack labeled Subwoofer Audio OUT.
If you have a 3-plug RCA cable that is a composite video cable. The yellow plug carries the video, the red and white carry the audio signal. This cable is most often used for connecting older VCRs and game systems to a TV (or newer devices to an older TV). Thus leave the yellow jack dangling if using it for an audio cable.
Set your TV to use the external audio speakers and the receiver will take care of the signal to the subwoofer. (You only would connect the speakers individually for a computer sound system.)
I hope this helps.
How do I hook it up to my Surround sound reciever?
Hooking up a subwoofer is dependent upon what hookups are availble on the receiver and subwoofer. Does your receiver have a specific subwoofer output? If so, is it set of speaker-wire terminals, or is it an RCA jack? The Wharfedale can accomodate either one of these as an input. There are four speaker posts on the back of the subwoofer, and there is a single RCA jack input.
2helpful
Have an RCA remote i am trying to use with my Vizio 1080p hdtv. Instructions on the universal remote are as follows: -Turn on TV -Press and hold "code search" untill light stays lit. release. -Press TV...
Newer brands of tvs are using new codes that old remotes don't have. Only older learing remotes from original remotes or USB upgradable or newer one that were made after the tv was made will work.
2 RCA's coming from amp into radio's single subwoofer output RCA?
You can either hook up the left channel only or buy a splitter that separates one input into two outputs.
2answers
Connecting Powered Subwoofer to a Receiver
you will need a line-level converter to use this subwoofer- it is a rectangular-shaped box with wires coming out on one end and red-and-white RCA plugs one the other. The end with the wires coming out will hook to the receiver, and the other end will need to plug into the sub.
Need help hooking up a KRK powered subwoofer to an Onkyo 7.1 receiver
a single male rca spliting into 2 male rca's ....a signal splitter
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
