Televison & Video Logo
Sway Lee Posted on Jan 14, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to get a ge universal remote to pair with a sanyo tv
Level 3:
Top Expert:
  • Sanyo Master 76,851 Answers
  • Posted on Jun 27, 2021
Sanyo Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007154
Points
237762
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
https://homehol.blogspot.com/
5 Related Answers
Anonymous
  • Posted on Sep 19, 2008
SOURCE: sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Anonymous
  • Posted on Jan 13, 2010
SOURCE: i need remote control codes for my GE universal
Need Code for GE RC24991-B Remote Control
Anonymous
  • Posted on Mar 04, 2010
SOURCE: I need to program ge universal remote jc024 for
I also lost the manual for my GE JC024 Universal Remote. I remembered though that you just hold in the button for the device you want to program and the "SETUP" button at the same time for about 5 seconds until the red light on the remote flashes and stays lit. then let go of the buttons.Then you basically just press and let go of the on/off button, pausing for a second or two in between presses until your device turns off. then you have to press the "ENTER" button and it'll store the code for that device. This method just cycles thru all of the possible codes for that device. sometimes you get the wrong code and the remote wont completely work. like hitting the volume button makes the tv mute for example. just repeat the steps until the device turns off again and eventually you should be able to get it. hope this helps.
BElectric
DILLIGAF
  • 1140 Answers
  • Posted on Oct 16, 2010
SOURCE: i have a ge 24911 universal remote how can i setup
Please rate this solution if you find it helpful. Thanks.
These are the codes for Sanyo TVs:
0049 0097 0110 0004 0268 0012 0108 0180
If you need any further codes, you can download the full list from here (free):
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
Also, if you need any instructions for programming your remote you can download the manual here:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/24912-Manual-Eng-Spa.pdf
Hope this helps.
gopakumarg43
  • 76851 Answers
  • Posted on Oct 30, 2011
SOURCE: GE universal remote code for sanyo tv?
Hello
Three digit universal remote codes for Sanyo TV with GE remote are:
049/097/110/004/268/012/108/109
/ 013/ 180/ 209
Four digit universal remote codes for Sanyo TV are
OK
Trying to pair my Yamaha remote to a Sanyo TV need the code
It can't be done, they are not reprogrammable, not universal.
universal remote codes for Sanyo tv with Instructions
Brand Code SANYO 0049 0097 0110 0004 0268 0012 0108 0180
Codes for ge remote to a sanyo tv
GE would have the codes for their universal remote. I would give them a call. However, if the universal remote doesn't work, you may want to try www.remotes.com. They have original remotes and replacements for the originals if Sanyo is no longer making the remote for your TV.
1helpful
Can you give me the codes for a sanyo tv for a universal remote
try this link...4 digit GE codes for TV sets including LCD, Plasma, and Panel TVs Brand Code SANSUI SANTECA SANYO SCOTCH 224 more rows
4 digit codes for TV sets including LCD, Plasma, and Panel TVs - GE ...
www.eliztech.com/remotes/ge-4digit-tv-codes.php codes for sanyo tv for universal remote Google Search
I have a sanyo TV and i need to scan cable channels, there is no menu button on it and no remote.I tried a ge universal remote and it. How can I achieve this? Is there an app...
Your GE Universal remote needs to be programmed to match your Sanyo model 32648 TV.
Please visit:
https://jascoproducts.com/support/ge-universal-remote-codes
It will tell you how to determine which version of GE universal remote you have, and how to program your remote.
Then you will need to use the Sanyo manual to perform the scan:
http://www.manualslib.com/manual/317727/Sanyo-Dp26648.html#manual
INITIAL CHANNEL SEARCH is on page 9.
32helpful
Hello
/ 013/ 180/ 209
OK
I'm trying to obtain the remote control code for a SANYO (model#AVM-1906). I'm trying to program it into a universal GE tv remote.
Hello
Univeral remote code for TVs with GE universal remote are:
0047, 0051, 0055, 0021, 0178, 0027, 0135, 0282, 0451
Three digit remote codes for Sanyo TV with GE universal remote control are:
049/097/110/004/265/012/108/180
OK.
Need unversal tv remote GE, for sanyo tv...
try walmart / bestbuy / jandr.com or even duane reade for universal the codes for sanyo is in the booklet that come with the remote...look at the type 3 to 6 (depend on how many items you want to control w/ remote) tv/dvd/vcr/cable box etc
4helpful
Sanyo tv codes
lost remote for sanyo tv now have a G E universal remote and i need the code to work the tv
213helpful
15answers
Sanyo tv codes
Any ideas?
1helpful
5answers
Need code for sanyo tv
Welcome to FixYa.
SANYO TV Codes: 0154, 0159
Please be informed that the codes vary with different make and model of the universal remote that you have. If none of the codes above work, please post back with make and model of your universal remote included.
Thank you for using FixYa.
Jas247
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
