Vizio circuit is very confused, as they have no service manuals of their own. you cannot get any details about it, or any service help. Your son, whatever he may be, cannot set it right because, there is no details about it. Please forgive me. I did expressed my service experience, with 46 years. OK? If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
SOURCE: Problem when getting High Voltage on Hitachi 65SWX20B
Draude:
I was wondering whether its worth changing the boards or to replace parts on the existing board. When TV powers up, I don't have any issue with the convergence. So I am thinking it may be power supply board. Do you think there is any problem with the deflection board. Is this board involved in supplying horizontal ( high voltage ). Do you think its better to change both boards. Any suggestions.
SOURCE: I am trying to replace the main board on my GE
No trick . May have to wiggle the connector to remove , but it comes off just like the other recepticals .
SOURCE: Replace Front suspension control arm
MAKE SURE YOU HAVE WEIGHT OF VECHICLE RESTING ON JACK STANDS.PLACE JACK STANDS UNDER THE FRAME.THIS WILL TAKE PRESSURE OFF SUSPENSION SYSTEM SO YOU CAN GET CONTROL ARM BACK IN PLACE.
SOURCE: Intermittently my Vizio model e370va volume will
I was having the same issue. I found this on Fixya and it seems to have worked.
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
SOURCE: My Visio 50" Plasma Model#
Have you removed the back and looked for Bad Capaciotrs on the power supply board?
Capaciotrs will be vented or puffed up on Top. 1000uf 16v,2200uf 10v 3300uf 10v etc....
