SOURCE: amana microwave model hdc 12 keeps blowing fuses inside
Check door switch.I think you find it bad.
SOURCE: blowing 25 amp fuses
In that case the outlet your using is pushing out too much electricity. Try calling your local electric company for help or a professional electric repair man.
SOURCE: microwave blowing fuses
Sanyo isn't that great of a manufacturer.. I had a microwave from them a few years back that did the same thing.. The wiring inside the microwave is shot.. if you were to open it up, you'd probably see some burnt wires from a short. If you use the microwave over a range, it may be because of grease build-up...
anyhow, its better that you invest in a new microwave, rather than fix it. It will be much more cost efficient
SOURCE: keeps blowing fuses
This problem is just like my own microwave, replace the shorted HV capacitor
SOURCE: sanyo EMS1000 microwave. Keeps blowing 13amp plug fuse.
New or older wiring to microwave? Is there a GFI circuit installed?
