SOURCE: welbilt bread maker
This link gives the most comprehensive detail about welbilt breadmakers - welbilt have gone out of business so there is no longer any direct online support; http://www.recipelink.com/abm.html however there are instructions, recipes, discussion forums etc. - hopefully more than adequate. Hope this helps :)
SOURCE: Parts for Welbilt ABM3500 Bread Maker
Hello, Here is a great website which lists out many resources for obtaining parts for bread machines. Good Luck! Dr. Know
SOURCE: welbilt bread maker model#abm600-1
Hello, you can find this item on ebay if you click HERE
Good Luck! Dr. Know
I found some parts at the gourmet depot website for Welbilt bread machines. Try www.thegourmetdepotco.com, and search on Welbilt under "parts." I found several dough blades there. Not sure about other parts, though.
It sounds as though your timing belt has broke. The timing belt, located at the bottom of your machine, drives the kneading paddle to mix the ingredients. You'll need to remove the bottom cover to verify my guess.
Did this answer help? Please rate it as soon as you can. Thank you.
