Baking soda paste applied to the face for two minutes is reckoned to help with acne breakout. Massage in using a circular motion, leave for 2 minutes and rinse off. Apply a moisturiser. Link below to search results...
https://www.google.com/search?q=BAKING+SODA+FOR+WASHING+FACE%3F%3F&rlz=1C1CAFB_enGB673GB676&oq=BAKING+SODA+FOR+WASHING+FACE%3F%3F&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
SOURCE: clean clothes that smell bad
Peace,
ngafm at your service!
You may have a small amount of water or lint lift in the machine somewhere that is not completely dumping out !
This is sometimes common on front loaders! Or the pump is weak!
I tell my customers to try running the washer without clothes once a week with hot water and a 1/4 cup of bleach!
. BUT the first load you do after this must be white in case there is a drop of bleach left in the system, that it does not spot bleach a white spot on your colored clothes!
If not this does not remedy the situation you will need hands on service!
please rate me here at our site before you sign off!
Thank You!
SOURCE: My sears top loading washing machine has a HORRIBLE odor inside.
if it smells like something dead you may have a dead mouse somewhere inside cabinet
SOURCE: I have sour mildew smell problem with my clothes
Look inside the door to the gray rubber ring gasket thingy. Pull apart the sides and look in. Betcha a dollar to a donut there's mold in there. It's a gross, nasty problem whirlpool customer service doesn't give a damn about.That's where water sets after wash cycles. There are tablets call "Affresh" which can be run with hot water for a cycle to attempt to clean out the mold/mildew. Not cheap, not fair, and probably will only be a start to a maintenance type cure if you've had the washer for awhile. May take some manual labor with bleach as well. NOT a sanitary washer. This is an unbelieveable problem with a washer. Piece of ****.
