Question about Plumbing
Facet water only dribbles out. replaced stem and its the same
2 Suggested Answers
Anonymous
SOURCE:
ray gallant
  • 66490 Answers
SOURCE: How do you replace shower facets in a holiday ramler endevor.when you take old facets out how do you connect water lines to new facet
very carefully but just the same as in your home .I personally like to use the new FLEX lines .
Posted on May 11, 2018
The hot water is not coming out the tap in the bath,only slight dribble,it wont turn on fully also.
possibly some sediment caught in the cartridge or stem. put some water in a bowl or sink, turn the water off to the fixture, remove the cartridge or stem, flush the cartridge or stem in the water, check for blockage inside valve body, replace parts, turn on water.
Dec 05, 2010 | Home
How to repair facet stem for glacier bay products kitchen sink
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Hot watwer leaks from the hot side of the facet
Replace the stem assembly (ceramic cartridge) with Price Pfister service part #910-030. Be sure to turn water on briefly to flush out any debris in the valve body before installing new part. NOTE: this valve does not like old galvanized plumbing.
May 21, 2010 | Price Pfister 01-31xa Shower Head, Tub...
I have a Moen shower knob that broke...
You are not the first. Usually you must break the plastic handle to remove it and then you can access the screw and have leverage to hold the brass stem with pliers while you try removing the screw. Caution, do not try to bend the handle to break it off or you will break the brass facet stem. Also, there are two styles of handles: one has a short innercone,the other has a longer inner cone. You need to know this before you purchase a replacement. Goodluck< Macgivor
Dec 27, 2009 | Moen & One Handle Tub & Shower Faucet
Warmer water
take handle off and turn stem 180 degrees and put handle back on,...should be fixed.
Nov 04, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Water won't stop after removing a electronic water timerfrom hose
turn off water ar meter
remove valve or guts fron tap on wall and replace ruber washer
option 2 go to wallmart and buy a mini ball valve screw it on wall facet and turn it off voila it now turns off 3.99 and your grass is no longer a swamp
Jul 25, 2009 | Garden
My Danze Anu Kitchen Faucet
Sounds like you have hard water.  You need to change the inside of the facet.  before doing anything make sure you CAN get the parts for you facet.   Danze are not very expencive you might just get a new facet.  If this is a hard water problem you might want to buy a moen facet with a life time warrinty.  More money but free replacement parts.
Apr 04, 2009 | Plumbing
Grohe kitchen facet 33 759 clogged
check the airraider on the spout of your faucet it unscrews and can build up with junk and sadly some times sediment works its way in to your faucet and clogs the stems and with a grohe faucet being as pricey as they can be i sugest replaceing the stem as aposed to getting another grohe faucet
Mar 28, 2009 | Plumbing
Losing hot water in one facet only
There is something in the line or in the faucet.Are your pipes going to the faucet black iron or galvinze.Some of the pipe will rust up and stop a full flow of water.But I would check the faucet first to see if the screw is loose or somethng in it.
Mar 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Bath tube plumbing is making vibrating sound then shutting off
Replace the cartridge even if its new. The vibrating is from the internal workings of the stem. It also effects the volume of water.
good luck, Phil
Dec 11, 2008 | Plumbing
Plumbing Logo
42 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
