Question about Miscellaneous
On myvegas rewards can in get a bogo buffet and also a free buffet to use at the same time
    Top Expert:
  • Miscellaneous Master
  • 30,888 Answers
In the small print it usually say 'May not be redeemed in conjunction with other offers.
https://www.google.com/search?q=on+myvegas+rewards+can+in+get+a+bogo+buffet+and+also+a+free+buffet+to+use+at+the+same+time
Posted on Jan 13, 2020
What is the correct way to pronounce buffet?
Many people pronounce the word "buffet" as buffit (rhyming withMs. Muffit). However, this isincorrect. Buffet is originally a Frenchword and should always be pronounced like "buffay" (to rhyme with "houray")
May 29, 2012 | Furniture
The bottom of the oven does not heat only the sides, is this the correct operation of the oven?
ooking with a convection oven requires some adjustments, but may prove much easier and more rewarding in the long run. Because the heated air transfers heat more efficiently to cooking containers and exposed food surfaces, food will take less time to cook. Most recipes can be cooked for 25% shorter time, which ends up saving energy. The temperature at which food cooks may need to be lowered slightly on a trial and error basis.
Oct 30, 2010 | Rival 18 Qt Roaster Oven with Buffet...
How can i use my reward points earned in sbi credit card
Hi, they explain it on their website: https://www.sbicard.com/creditcards/faces/pages/CreditCardRewards.jsp
Redeeming Power PointsWith the Shop & Smile Rewards programme every time you use your SBI Card you get Power Points. These Power Points can be redeemed for exciting rewards. Here is how you can get them:
Check your latest Card statement to see if you have accumulated a minimum of 1000 points.
Call the SBI Card helpline 39020202, if calling from BSNL/MTNL line dial 1860 180 1290 | 1800 180 1290 OR
write to us at PO Box 28, GPO, New Delhi- 110001
We will have your gifts delivered at your doorstep!
Aug 02, 2010 | Philips Kitchen Appliances - Others
I want to buy the buffet server for the roaster. My roaster did not come with the buffet server.
Rival akes several 18 quart roasters and not all of them take the buffet server. You can check about yours and order direct on line at the Rival website:
http://www.rivalproducts.com/category.aspx?cid=1117
Nov 22, 2009 | Rival 18 Qt Roaster Oven with Buffet...
I need a cooks essentials item
From time to time I see them on mrpearl11.com. Last year I had a big party for Halloween and needed the buffet inserts badly. After scouring the web, I finally found them. The closer it came to the date of my party, the more stressed I became. Finally, I found them at Mrpearl11.com. I saw them on the site earlier in the year but I didn't really need them at that time. Hope that helps.
Dec 22, 2008 | Heating & Cooling
Miscellaneous Logo
24 people viewed this question
Top Miscellaneous Experts
Rachael Newton
Rachael Newton
Level 1 Expert
William Miller
William Miller
Frankie B
Are you a Miscellaneous Expert? Answer questions, earn points and help others
