Cell Phones Logo
Nicole Moise Posted on Jan 13, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Since ios 13.3 notifications don't go on charger 3
Attique-ur-Rehman
Level 3:
Top Expert:
  • Master 2,677 Answers
  • Posted on Apr 21, 2020
Attique-ur-Rehman
Master
Level 3:
Top Expert:
Answers
2677
Questions
Helped
879816
Points
8006
Https://www.youtube.com/watch?v=X0U4g1Uq9Yo
IPHONE users with Fitbits have been struggling to get some of their fitness tracker notifications to work ever since Apple released the beta version of its iOS 13 software. There is currently no fix for broken bands so users have taken to social media to vent their frustrations.
https://www.thesun.co.uk/tech/10228878/fitbit-iphone-ios13-problem-no-fix/
tip
How to Fix iPhone Not Vibrating?
If you are in a meeting or attending a special event, you probably set your smartphone to silent mode to avoid any distractions from your phone. But what if there is an emergency? You will miss the calls and texts from your phone and then regret it later after realizing that it is a very important matter that needs to be discussed with you.
If you don't want to disturb your meeting or the people around you when your phone receives calls or texts, then choose to vibrate mode instead of silent mode - at least you will be notified if your phone receives any notifications. But what if you are using an iPhone and you learned that the vibrate mode is not working. What would be the reason behind it?
/uploads/images/fix-iphone-not-vibrating-undefined-undefined-0.jpg
Fix iPhone not vibrating
Now, if your iPhone is not vibrating when it receives calls, texts, notifications, or when you switch on the ring or silent mode, then you need to learn some of the solutions to fix this issue. Here are the 3 effective solutions that you need to know.
Solution 1: Check the iPhone Vibration on Sound and Haptics Settings
One of the basic things that you should learn about your iPhone is how to set the phone settings, especially the vibration mode. If your phone is not vibrating, go to your iPhone settings then navigate to the sounds & haptics option and check the vibration mode from ringtone to text tone - if off, turn it on. Then disable the focus mode that restricts the vibration of the app's notification.
Solution 2: Check the iPhone Vibration on Accessibility Settings
After enabling the vibration in the sound and haptic settings but still your iPhone is not vibrating, then go to the accessibility settings and check the vibration mode is turned on.
Solution 3: Fix iPhone not vibrating via iOS System Recovery
If the first two solutions didn't work on fixing the vibration issue of your iPhone, don't worry. With the iOS System Recovery, all iOS errors will be fixed including the vibration issue of your iPhone. This reliable tool can quickly solve any type of iOS error.
on Jul 14, 2022 • Miscellaneous
2helpful
How do update my IPOD with ios8
1. Over the air:
1) On the homepage of your iPhone iPad or iPod touch, open Settings and click the "General" option, and then select "Software Update".
2) Click the "Download and Install" button to begin download the iOS 8 installation package.
3) After the iOS 8 installation package is downloaded successfully, click "Install Now". Then your device will restart, and you can experience the latest iOS 8 immediately!
2. With iTunes:
1) Connect your device to your computer, and iTunes should launch automatically. If not, open it on your computer.
2) Click your device icon from the left side bar, then tap the "Summary" tab.
3) If there is no notification about iOS 8, click on the "Check for Update" , and then click "Update". When the download is complete, your device will restart and install the new OS.
How to Install iOS 8 on iPhone iPad iPod touch iMobie Guide
How do I get rid of a silly graphic weather widget which overrides my weather photos after I accepted it?
Adding & Removing Widgets and Items from iOS Notification Center
Don't care to see Reminders or Stocks in your Notifications screen? You can add or remove anything:
  1. If you haven't already, unlock the iOS device swipe down to bring about Notifications panel
  2. Select the "Today" tab and choose "Edit" at the bottom of the list
    • Delete Widgets from Notifications: Tap the red (-) minus buttons alongside items to remove them from the Notification panel
    • Add Widgets to Notifications: Tap the green (+) plus button to add a widget to Notification Center
  3. Choose the "Done" button in the upper corner to set the changes in place
Any adjustments made to Notifications Center here will be visible when accessed from either the lock screen or elsewhere in iOS.
How can I delete my notification
On which system is the notification on?
Windows? Linux? Android? iOS?
And what does the notification says?
App notifications on iPad
Notification Center settings: define what's shown To access Notification Center's settings, navigate to Settings > Notification Center. From there, you can select what elements which appear under the Today view. You can also disable or set how Notification Center alerts you for each of your App's notifications: via a banner or via a pop-up message.
app-notifications-ipad-0tb34kwmyoceio04eaynqm4i-4-1.jpg iOS 7s Revamped Notification Center app-notifications-ipad-0tb34kwmyoceio04eaynqm4i-4-6.jpg
Iphone task and calendar alerts disappear when I enter password
Depending on the OS you are running they are in Notification Center(iOS 6 and Later). You can access Notification Center by swiping down from the very top of your screen in iOS 7. You can change Notifications on an app by app basis in Settings, Notification Center.
In the iPhone Good for Enterprise app, is there a way to disable push updates. I would prefer to have it check a few times per hour than constantly. I think it is causing a drain on my battery. I have...
I don't have an iOS device on me at the moment, but in your general device settings. There should be an option for notifications. And inside of the there is an option for Good. You can disable or customize the push notifications. Also note that due to the iOS freeze states the Good application can't process in the back ground after about 5-10 minutes away from the app. It will still request push notifications on an OS level from the Apple Push servers. But that can be disabled in the above notification settings.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
