Most treadmills will produce some sort of error code if everything is ok in the the lower control board, but you get no response from the motor when pushing the start button.
First verify the motor is functional. I use a 12v 9ah battery commonly used in a Vexlar fishing system, but I have even used the connection points on my cordless drill battery to make a run. Using one of these small power source will make the motor/belt move, but you will be able to easily make the belt stop if you were to step on the walking belt. The point of the exercise is to verify the motor is operational.
If the motor is operational and the unit still does not throw a code or recognize there is an issue, then you can feel about 90 percent confident it is the lower control board under the hood that supplies power to the motor.
The “click” is often some capacitor opening and attempting to send power, but another path way on the board is holding the system back.
Lower control boards go out commonly. They can just have a defect or they are the result of too much stress.
SOURCE: Perfection 2400 scanner fails to scan; just clicks
The only thing that usually causes a scanner error of this type is either a scanner failure or the transport lock. Locate the lock and make sure it is in the unlocked position. Lock and unlock a few times leaving it in the unlocked position then power the scanner off and on again.
SOURCE: Broiler will work, but oven wont
Could be the bake igniter is bad and broil igniter is still good. may need to replace the bake igniter you will need a complete model number off range to determine the part number of the igniteryou may need.
SOURCE: 1998 Chevy Blazer 4x4, $ wheel drive won't work (both 4hi & 4lo )
Reset the computer by disconnecting the battery. This should solve this. nutetral is for the four lo only to engage.
Mike
SOURCE: Treadmill motor not coming on, belt not moving
most likely cause is a burnt out motor controller, you'll need to replace it.
SOURCE: Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
