Heating & Cooling Logo
Monica Eastham Posted on Jan 12, 2020
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor 422 what does the flame inside the heater look like if running normally?
Vernon Taylor
Level 3:
  • Heating & Co... Master 7,446 Answers
  • Posted on Jan 12, 2020
 Vernon Taylor
Level 3:
Answers
7446
Questions
0
Helped
1955930
Points
26207
I don't know exactly as I have had no experience with forced air paraffin or kerosene heaters of this design but I would guess an ideal flame would be blue, though an ideal flame is likely to be difficult to achieve and there is likely to be some yellow flickering tips to the flame.
A large amount of yellow indicates the heater either had an excess of fuel or insufficient combustion air - either way it is inefficient, producing less heat and creating soot that will soon worsen matters. Below are a couple of links you might find useful...
http://monitorproducts.com/wp-content/uploads/M422OwnersManual.pdf
http://cleanflametrap.com/bruce_monitor.htm
3 Related Answers
Anonymous
  • 126 Answers
  • Posted on Apr 25, 2009
SOURCE: have monitor 422, have had it serviced and flame
JM,
When you have a smell from a Monitor you have a real problem. You need to get to the bottom of the problem as soon as possible due to the chance of CO gas. If the heater was just serviced I would look at the connection for the exhaust on the back of the stove. The little Z pipe needs to be all the way in on both sides. Monitors are close to the wall and sometimes it's very hard to get that pipe all the way in. Since it is a serious problem I would look at all the gaskets on the burner and heat exchanger to be sure none are missing or broken.
I can't stress this enough. If you are smelling fumes from a Monitor you must get to the bottom of it before you continue to use the heater.
Tom Hawkins
[email protected]
Anonymous
  • 4 Answers
  • Posted on Dec 31, 2009
SOURCE: heater won't ignite on Monitor 422
check out solution for mon 41 it is same
Steve
  • 3290 Answers
  • Posted on Apr 17, 2015
SOURCE: is the monitor 422 heater considered a direct vent wall heater
Yes, the Monitor 422 heater is direct vent type.
You must install the supplied double-walled vent tube between the heater and outdoors. Failure to properly install the vent tube will quickly deplete oxygen from the space it is operating in. That is a potentially deadly situation.
The pipe is special. The inner pipe is for hot exhaust gasses to be sent outside and the outer walled pipe is for fresh combustion air to be brought into the heater. This set up is why the heater does not create drafts in the home.
Monitor 422 Kerosene Heater. It runs for about an hour then shuts off.
Here is some information and your Service Manual with a Troubleshooting section.
cleanflametrap.com http://cleanflametrap.com > bruce_monitor
Monitor 422 · The Monitor is a computerized kerosene heater. · Here's an odd accumulation at the burner base. · Here the top panel is ajar and the upper front ..
monitor 422 specsmpi monitor 422 manualmonitor 422 heater troubleshooting mpi monitor 422 burner status flashingmonitor 422 partsmpi monitor 422 flame sensor
Monitor 422 Service Manual - ManualsLib
ManualsLib https://www.manualslib.com > ... > 422
View and Download Monitor 422 service manual online. MONiTOR HEATING SYSTEMS. 422 heating system pdf manual download. Also for: 22, 21, 41, 441, 40.
May 16, 2023 • Garden
Is the monitor 422 heater considered a direct vent wall heater
CO2 and flame "dancing"
This normally is caused by low gas pressure, or some blockage in the burners. Do not run this heater until it is fixed.
1helpful
3answers
Monitor 422 lights then goes out
Sounds like your flame rod may be dirty. You can take it out and clean it with some steel wool or sandpaper or emory cloth. If this doesn't help email me at [email protected].
Have monitor 422, have had it serviced and flame pot replaced, but now it smells of kerosen when it is running, makes the whole living room smell. any suggestions
JM,
Tom Hawkins
[email protected]
2answers
I have a Monitor 30, it comes on and just runs, it will not lite until I lift the primer once or twice, then it heats fine. I checked the filter and made sure the tank was high enough for a 5 gallon...
Rob,
You have some kind of fuel problem. When you mention 5 gals of fuel, that leads me to think you need more fuel ( more pressure). If you have a large tank and only have 5 gals you may no have enough head pressure to push the fuel through the line and all the filters in the system. That being said the Monitor 30 is the oldest vented heater around. Parts have not been available for 15 years. The thing that scares me about the M30 is the flame safety circuit. I don't think it is adequate. If you rely on this heater to keep pipes thawed I would get a new Monitor or Toyo.
Tom Hawkins
[email protected]
2helpful
3answers
I have a monitor 2200 that is reading ee 13. what does that mean?
EE13 on a Monitor is one thing. The same code on a Toyostove is completely different. A Monitor EE13 means there was no flame at ignition. On a toyostove EE13 is the burner thermistor.
On the Monitor I would check my fuel tank. On the Toyo you may have to have the dealer help you, as it could be something easy like a very cold day or more complicated as a main circuit board.
Tom Hawkins
Bethel, Alaska
12helpful
3answers
Mpi monitor 422 heat problem
I had the same problem last night and this morning. Its in the manual. I had to take the fan off of the back and vaccuum out all of the dust/lint that built up and it was a lot. It is a safety feature. It's a overheating protection feature that usually triggers if there is build up in the fan, front vent or vent pipe to the outside. I hope this helps.
Top Heating & Cooling Experts
Paul Carew
john h
