Question about LG Televison & Video
Have a lg 65uh5500 turn it on and the power light blinks twice and the lg logo comes on the screen then it shut itself off.
4 Suggested Answers
Anonymous
SOURCE:
Anonymous
  • 7 Answers
SOURCE: power light blinks, but tv won't come on
I have the 52" version of the Viera model. Mine went out last night and started blinking twice over and over again. I suspected overheating so i just went to bed and tried it in the morning with no luck. Then I unplugged it for more than ten minutes and plugged it back in and everything worked fine. I hope this helps.
Posted on Oct 01, 2009
SD Tech
SD Tech
  • 14553 Answers
SOURCE: wd-65737 screen comes on with mitsubishi logo then shuts off ,red light blinking
Here is a suggestion that has worked for several people:
http://www.fixya.com/support/t12296849-turns_off_shortly_after_turn?mt_f=viewFull162
Posted on May 30, 2012
Larry
  • 2800 Answers
SOURCE:
Another set where the LED's in the panel are shorted and dropping the rail down for them, you will need to take the panel apart and replace the bad lamps or strips but this isn't an easy job to do its very easy to damage the panel after fixing the lamps and have to throw the set out after all that work
Posted on Mar 20, 2018
I have an LG 65UH5500. When turned on the screen briefly shows the lg logo then shuts back off and the red led flashes twice. I’ve checked the output on the power supply and it was showing 66v board says...
Mar 19, 2018 | LG Televison & Video
LG 65UH5500 TV just died while watching it. Screen gone black, no sound.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 16, 2017 | LG Televison & Video
My LG 50" smart tv turns off right after I turn it on. The LG logo comes up then disappears then the red power light blinks twice and shuts off. The red power light then returns.
the number of blinks by model tells you information. Look up capacitor failures on that model on youtube. I have a vizio that did the same thing, and it was a $0.11 capacitor I had to replace... took about 30 minutes, and working great. You'll need to see if you can find someone with that same problem on youtube to be able to find it easilly... requires soldering iron... little screwdrivers and some patience. you can do it!
Jul 28, 2017 | Smart Cars & Trucks
Lg led tv doesn't turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices....
http://electro-medical.blogspot.com/
Jun 20, 2016 | LG Televison & Video
Power light blinks, but tv won't come on
Jan 08, 2008 | Panasonic Televison & Video
Televison & Video Logo
122 people viewed this question
Ekse
RONALD CARTER JR
